Question about iLO (2 GB) MP3 Player
It wont connect to comp..powers down
I connect to comp and manual says it will turn. Instead it turns on then off and wont connect...any suggestions?
  • CrabbyPS Jan 20, 2008
    My MP3 player shuts off when I connect it to my computer --- someone said I need new hardware --- what is that suppose to mean?? I've updated my Windows Media Player and tried to re-install what I have but nothing works.
    Problem Solver:
  • 5 Answers
You dont have the correct hardware.
Posted on Jan 19, 2008
My radio on my 2005 Chevy silverado wont turn off when i turn my car open and open the door and its making my truck die, changed the ignition switch this did not help. Any other suggestions?
its making my truck die - What does that mean? Is the truck's engine shutting down while it is running, or is the battery being drained such that the engine will not start?
Is the radio ON even when the ignition switch is turned off? Your radio power wire may be connected to a point that is always on instead of to a point that is controlled by the ignition switch.
Oct 28, 2013 | 2005 Chevrolet Silverado
I have a 2005 tahoe 2wd it has 96000 mile on it i started it up yesturday and put it in drive it act like it didnt wont to go like it was in second instead of 1st i wnt down the road and it didnt wont to...
Has the transmission fluid and filter been changed in it in the last 50,000 miles.Sounds like you have some shift solenoids sticking.Change fluid and filter
Apr 20, 2011 | 2005 Chevrolet Tahoe
It wont switch on
try to remove the battery , then press and hold power button for 8 secs. Then insert the power cable instead of battery. Turn it on. If it wont, try to disengage the power cable and insert the battery. If still wont turn on, kindly inform toshiba about this problem and have them fixed immediately. It is either the battery, the cable or the pc unit itself that causes your laptop failure...
Mar 01, 2011 | Toshiba Satellite C655-S5139 Notebook
I'm trying to scan to my computer & I'm getting a msg "No connection. Turn on or connect comp. or install HP software." I am connected to the printer. Can you help?
First step for ANY HP product is to first power it down completely, which means disconnect all of the cables from it, usb, printer, power supply, etc., and let it sit for a minute or two. This will usually allow the printer to reset its processor upon powering up.
If your PC does not recognize it at that time then I would suggest re-loading the drivers that work with your operating system.
After that all I can suggest is that there is a bad usb port, or whichever connection is being used...
Nov 20, 2010 | HP PSC 950 All-In-One InkJet Printer
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
DOES NOT START SHOWS BLACK SCREEN
do a power drain
- shut down the comp, unplug the adaptor and unplug the battery
press and hold the power button without any power connected to the comp
- plug the battery and plug the ac adaptor and turn on the comp
Oct 04, 2009 | HP Compaq nc6220 Notebook
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
