Question about HP LaserJet 2430dtn Printer
Hp Lj 2430TN Printer
My Hp Lj 2430 TN is telling me to "install black cartridge". I've tried 2 cartridges with the same message....Suggestions??
Thank you
Knightly
  • knightly Jan 20, 2008
    Tried a 3rd cartridge...OEM this time...Printer still shows the same message
  • Yan Ducharme May 11, 2010
    are they genuine or compatible type of cartridge?
    sometime the chipset on some compatible model are just faulty.
We ran into this problem a lot when this series first came out. There is a simple sensor on the left hand side of the toner cartridge area inside the printer that physically detects that a toner is installed (or not). With the left cover off, there is a plastic bracket that holds a lever; unless it is not, then it tells you that you have no toner installed. Lame.
Posted on Jun 24, 2008
  • Anonymous Jul 14, 2015
    this was my problem as well. The actuator was wedged in place thinking there was no cartridge. Thanks!
  • 417 Answers
I agree the chipset are sometimes faulty also try taking the cartridge out and using a soft cloth wipe the area clean where the chipset go as there maybe toner on the receivers.
Thanks J
Posted on Jan 17, 2008
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Laserjet 2055 install black cartridge error
hello for all my dear the problem in hp lj 2055 install black cartridge error massege here the solve iam engineer in hp service center and i meet that problem in my daily work the problem in dc control must t replaced sure 100%
May 30, 2012 | HP P2055DN LaserJet Monochrome Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Print cartridge will not install on HP LaserJet 3800n
common problem on the hp lj 3800, you'll notice if you shine a torch in the area where you found the broken pieces of plastic, there will be some more, it is this which is stopping the toner cartridge from sitting properly in the printer. Don't worry about the broken plastic the printer will still work ok.
Oct 21, 2008 | Office Equipment & Supplies
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2430dtn Printer Logo
368 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
