Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Canon eos 300d - image to dark
I am using the Canon Speedlite 420EX every time I take pictures. On the
LCD screen the picture looks like the flash went off, but when I download
the images to my Photoshop programme the images looks like I didn't even
used the flash. I then need to make adjustments which result into a low
quality image. I put in new batteries into the flash, but the results stays the same. The flash take forever to show the green light when it is ready to
take pictures. Due to my work I cannot wait so long before the next picture were taken. Is there some settings on the camera or photoshop that I need to adjust or is there something wrong with the flash.
Try lithium batteries or rechargables in the 2500mah range,to me they seem to work best in a flash.
If you use alkalines,use a well known brand.But with alkalines,as they loose power it takes longer for the flash to recycle.
Also the monitor might need to be calibrated or adjusting brightness and contrast.
Mine sometimes does the same thing,I just use Photoshop to adjust it.
Posted on Mar 06, 2008
6ya staff
SOURCE:
Flash speedlite 420 ex not works well with canon 7d
What are the issues your having? Without an idea of what the photos look like and what settings you are using there's not much help we can offer.
Apr 09, 2014 | Canon Speedlite 420ex Flash For Xt Xti Xsi...
Tip
How to Disassemble 420EX Flash
I wrote up on instructables how to disassemble this flash for anyone needing a guide.
http://www.instructables.com/id/How-to-Disassemble-a-Speedlite-420EX-Flash/
on Dec 04, 2007 | Canon Speedlite 420EX TTL Flash
Can a canon speedlite 200e work with a nikon dslr ?
The Speedlite 200e was developed to work "exclusively with [Canon] EOS [film] cameras" according to the manual. It is not even compatible with Canon digital SLRs. Most modern (digital) SLRs control the strength of the flash to properly expose the pictures being captured.
The flash will probably fire when used with a Nikon DSLR but there is no guarantee that the images will be properly exposed. Also, the flash is designed to properly illuminate focal lengths of 35mm minimum. If you are using a wider lens (i.e., 24mm or 28mm) the edges of the image will not be adequately illuminated.
Feb 10, 2010 | Canon Speedlite 200E TTL Flash
I need the Canon Speedlite 420ex manual.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=7394
Dec 31, 2009 | Canon Speedlite 420EX TTL Flash
Can the Canon speedlite 430EX be the slave to the 550EX speedlite
Most any slave light will work I use a old vivitar flash with a slave module in the cord to camera outlet woks gook for a fill light. helix camera .com ritz camera. or ebay don't digital flashes a little different than strobes i played with the settings until i got the desired lightng I wanted., if your camera has a hot shoe you can get a slave to fire an external flash with it.hope i helped
Dec 27, 2008 | Canon Digital Rebel / EOS-300D Digital...
Shooting with External Flash
Without more information, it sounds like the flash may be set to a manual mode. Try setting the flash to an auto mode. The display should indicate something to the effect of "E-TTL" or maybe just "TTL". The reason your images are blurry, would be due to a slow shutter speed being used on the camera. If your flash is not set to trigger automatically, then the camera will use the slowest shutter speed to acheive the proper exposure of the image. My assumption would be that if you were to take two images back-to-back with the speedlight set to your current setting, one with the speedlight the other with the pop-up flash, the latter would not be blurry. Hope this helps.
Dec 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Speedlite 420EX lost a plastic part
Part number: CY2-1130-000 PANEL, AF LED
Check you local canon.com for spar part suppliers
Dec 10, 2006 | Canon Speedlite 420EX TTL Flash
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
104 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
