Question about Philips DVDR3450H DVD Recorder/HDD Recorder
Problem Recording HDD to DVD-R
I have a philips 3450H HDD recorder. I want to put recordings on to a DVD-R blank dvd. I follow the instructions on screen.I select the recording which shows that it will fit on to the disc. When I press the hdd button to record the selected onto the disc the red light comes on and it displays 0% progress, nothing happens and it stops in a few minutes.
  • changi Apr 20, 2008
    will play but not record
    when trying to record useing DVD-RW the red light comes on and a lot of
    Zeros, when I try again it says that the disc is damaged
    when I switch on the TV screen shows top P1 Mono top left no disc
    bottom left no singal
    DVD recorder shows no ch
  • Anonymous Aug 24, 2008
    I have a DVDR3460H and it tapes to HDD OK but it will not tape direct to DVD or from HDD to DVD .The Red incation light come on with 0% sign and runs until I stop it .It will not stop with the usual stop button and have to be unplug at mains.What shall I do ?
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Posted on Mar 15, 2008
I purchased a dazzle dvd recorder. it has red and white audio leads ,yellow video lead . my vcr has only white audio. i installed program.followed the instructions. put put dvd and vhs in proceeded to...
I hate these little converters, much more trouble than they're worth.
The red and white leads provide stereo. As with VCR's just having a white phono out is quite common. There's just no connection for the red.
Its then a case of recording to your PC HDD, Edit the recording and saving the file. Finally burning the file to DVD.
You have to ensure that, assuming the options there, that you save your file as MPEG1 or MPEG2 or any file compatible with your DVD player.
In this case it looks like your "burn" failed for what ever reason. I'm afraid that disk is now a coaster. Have another crack, take your time, one stage at a time.
The way I do it, I've got a DVD recorder with a built in HDD.
Hook up my VCR to DVD recorder via scart and loop it through to a TV so I can monitor it.
Press record on the DVD and play on the VCR. When complete, edit the recorded file on my DVD then copy or dub to and finalize the recorded DVD.
Apr 29, 2010 | Computers & Internet
After a timed recording the DVD is showing blank
Try to scan the DVD data into your PC using the trial version of TMPGEnc v4.0 Xpress if this can't find structure data then the recorder must have set the leadin data to show blank.
Nov 13, 2009 | Philips DVDR3380/05 DVD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Copy recorded pgms off DVD HDD to DVD+RW
the manual specifies that if you select for recording the FR mode the machine automatically adjusts the recording mode for the program to fit on a 4.7G dvd. If you use a dvd DL if will auto detect that you have this type of dvd and the FR mode will automatically allow you to make full use of the available space. Depending on the space needed on the dvd the picture quality will be good to excellent (refer in the manual to Recording Modes..)
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Philips dvdr3455h/37 recording issues
I was having the same problem if I used DVD+R blanks, but the programs would record fine if I used Memorex DVD+RW rewritables. Until today, that is - now it won't let me burn anything from the HDD to a disk!  My 3455H is about two years old.
Gotta say I'm quite disappointed with it, and would never consider another Philips product. :(
Aug 13, 2007 | Philips DVDR3455H/37B
Downloading from hdd to dvd+r ?
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Jul 28, 2007 | Philips DVDR3455H/37B
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
301 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
