Frigidaire model CRWS5700AS0 washing machine burning belts
A neighbor gave us their (relatively) new washing machine when they moved. After the first few loads it started squealing and smoking. The drive belt had been burned where it sat on the motor pulley. Replaced the drive belt and everything was fine for about four months - lots of laundry going through the machine. Then yesterday it did the same thing. What's going on? Is it worth another belt? model CRWS5700AS0
  • 1 more comment
  • twbrown Jan 16, 2008
    it will spin both directions, but I already took the belt off... does that matter?
    OK, thanks. You should have an email from me now.
    well every time I try to click on the rating I get a message saying the webpage cannot be found. Anyway for those reading I will tell you that the info I got from TECH17 kept me from wasting more money trying to fix this machine. Definitely helpful! Problem couldn't be fixed but that's not his fault. Best of all he had answers for me in less than 30 minutes after I posted the problem.
    President:
  • 1,314 Answers
Check the tub see if with the washer off.See if you can spin it both ways . let me know and i will advise futher this will be the spin tub
Posted on Jan 16, 2008
Fridarre washing machine model fwx883as 1 burning smell does not spin
Sounds like the belt has worn out, is slipping (the burning smell) and needs replaced.
Jan 06, 2010 | Frigidaire FWS445RF
My washingmachine stopped working and gave off burning smell. How can I determine if its the motor thats burned out or something else?
Had one similar to this about three years ago. That burning smell would be the belt that runs the washer. Relatively easy to repair. You'll need make and model number to get the right replacement belt. Once you have it, get up under it, remove the old belt and put the new one on the same way. The belt will go around the pulley on the bottom of the washer drum, the motor and the tensioner. This should solve your problem. If you need more help, please let me know.
Oct 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Fridgidaire Washer burning belt!! Help
http://www.applianceaid.com/frigwestwasher.html#burnt-belt
look on this site for more aid, it may not be your exact model but has advise on burning belts
Nov 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Apr 12, 2008 | Washing Machines
Agitator will not move
Jac, my suggestion is this. The "reverse" gear in the transmission has locked up. The burning smell is coming from the belt. The motor is trying to spin the belt to turn the tranny but it won't turn  'cause it's locked up this causes the belt to burn.
If it's less than 5 years old, the tranny is under warranty. Contact Frigidaire and give them the full model and serial number and schedule a repair. (ask them to bring a belt with them when they come. you'll need one.)
Oct 11, 2007 | Frigidaire FGX831CS Top Load Stacked...
Open Questions:
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
