Question about Ricoh Aficio SPC210SF All-In-One Laser Printer
Could not receive and send Fax
I have just purchased the Aficio SPC210SF, but I can not send and receive fax to anywhere. The line from the PBX is connected through PBX into the line port of the SPC210. I have made several changes but it ended up with the error report saying it's busy. When PSTN is connected directly to this machine, I could send and receive fax without any problem.
Could anyone give me advice what needs to be changed?
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= [email protected]
Let me know is you encounter new problems?
Greetz
Richard Trip
Posted on Feb 15, 2009
6ya staff
SOURCE:
Why am I unable to send a fax?
Are you running ADSL on your fax phone line ? Will need an ADSL line Splitter with fax plugged into phone side of splitter. Could also be plugged into a PBX extension then you need to convert analogue to digital for PBX.
Sep 08, 2014 | Office Equipment & Supplies
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
Having problems with long distance fax transmissions - receiving number not receiving fax. Fax machine: Brother MFC-8220.
Is the 1 placed infront of the number, is the line part of a PBX system requiring to dial a 9 to get a outside line.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 13, 2009 | Brother MFC-8220 Fax
Sending fax from behind a PBX works, but receiving does not.
Since fax machines are ANALOG they don't understand routing through a PBX. You need a dedicated ANALOG phone line not tied in with your PBX system.
Jan 22, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Sending and receiving faxes
Do you have an analog phone line or are you trying to run it through a PBX system? I was just having this discussion with RKS tech support. Their fax software was hanging up as soon as the connection was established and all I had available was a VOIP phone line. It took 4 tries but I found a US Robotics fax/modem that worked fine in class 2.0 mode.
Nov 10, 2007 | OKIFAX 5650 Plain Paper LED Fax
Problem with the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Oct 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix my fax
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix the fax
Mode incorrectly switching to Handset
Hi Sue, Can you tell me if there is anything else conencted to your fax line? Most Ricoh products will display handset if the dialtone is not detected. It could be that something is using the line or is causing it to short. Another thing to check if the machine is an older 1515- if this occurs after you receive a fax and you are behind a PBX, there was a batch of modems in the Ricoh machines that had a problem with not disconnecting the line, resulting in the handset being displayed. Could be any number of items, normally I would start the troubleshhoting with line issues and go from there.. Brad
Aug 17, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh Aficio  SPC210SF All-In-One Laser Printer Logo
388 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
