If it is affected to your phone software ,then the only way is to re-program the phone with from the nokia customer care centre. If the virus is affected to your memory card then its better to formet it and re-insert it.
it is a error occured due to the attack of virus or by external shock
so pls change the software from nokia care
dont use the viruse affected memory cards & don't recive viruse affected datas from other phone
You can remove the mmc but keep the sim card and restart your phone.
Then press the keys *#7370#.
The phone would ask a confirmation.
Select yes.
Then it will ask for a code.
Type the phone lock code (the default code is 12345).
There you are! your phone will restart with all the phone memory formatted.
Tips
Also remember that you can reset your phone but not loose any of
your personal files (I.E restore the settings that came when you bought
the phone while keeping contacts etc) by following the above procedure
but using the code *#7780#
Warnings
Don't apply these steps if you are not sure what you are doing.
Make sure you have enough battery power before beginning this procedure.
Formatting will erase all your contacts/messages, so make a backup of your phone before formatting.
Just Reset Your Mobile Phone Settings RESTORE FACTORY SETTINGS Automatically Remove all errors from your mobile phones Before resetting Backup your Contacts Massages and All Gallery
Remove memory card and check. if same problem press *# 7370# on your mobile. Be sure that you have taken back all your phone data back. Phone will restart. Now check it with out memory card. if it is ok, Check your memory card for virus in computer with latest anti virus through a card reader.
THIS IS NOTHING BUT THE PHONE IS AFFECTED WITH VIRUS NAMED TROJAN HORSE/COM WARIOR........IF THESE ARE ATTACKED .....THE MAIN PROBLEMS
1.MSGS R FORWARDED AUTOMATICALLY TO SENDENRS
2.TEXT N MMS CANT BE DISPLAYED
3.MSGS DEFERS
4.PHONE RESTARTS
SO TO OVERCOME THIS PBLM JUST FORMAT PHOE N MEMORY CARD
PHONE FORMAT; SWITCH OFF FOR 5MIN ,AGAIN SWITCH ON BY PRESS N HOLDING THE 3 KEYS(*,3,CALL (GREEN) BUTTON),FORMAT COMPLETES.
MMC FORMAT; SCAN VIA SYSTEM WITH UPDATED AVG N REPLACE IT .
BY D ABOVE SOLUTIONS I HOPE U WILL SATISFIED..
this is a simple one that so many people ask ,there is no risk to do just do as i say
if u want to format memory card first format it,then
to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
