Question about Motorola Mobility RAZR V3
Power button works..
All the buttons dotn work on my phone except the red power button, i have tried turning it off, letting th ebattery sit out for a while, and stuff i dont know what to do
  • b-rice Jan 17, 2008
    only red bottun works
    Guru:
  • 167 Answers
If the only red buttons is working,
maybe your phone keypad flex ribbon is already damage.
or if you drop your phone and after that
the erd buttons is only function key keypad crystal is the prob.
Posted on Jan 17, 2008
Tip
Any phone Hard reset
HARD RESETHard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus.if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you.........All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile=>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well.HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction...IPhone 3G,3Gs, IPod Touch,IPad...=>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously .- Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo .For IPhone4 is no need to turn off as normally=>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation-slide across the red slider-hold two button above to turn on...* Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen .Nokia/Touchscreen with keyboard/N97,N97 mini,...=>Press and hold button shift/left+space+backspace,including power button and follow in struction...Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6...=>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem....* for N8 =>press volume down+camera+menu,including power button...Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60=>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well.* For Nokia,if the operation require code,the default code is 12345.* S80 press and hold Ctrl+shift+F* S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too.BlackBerry=>Press and hold Alt+Shift/right+Del,then follow the instruction...SonyErisson/Touchscreen with keyboard=>Press and hold right + left soft key,including press power button.../was try on X1i,no problem...SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research.You should know that Hard reset is the last solution,if none solved ur mobile problem.Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk-kindly do not edit this document.... :)Research and Prepare by YEKCHHUNHOUR.Inform me if you see any wrong instructions,to improve this doc better and confiding.Via Email: Chhunhour.kh@hotmail.com27/12/2010 VOTE FOR ME PLZ..........
on Dec 31, 2010 | Lands Phones
Power button failure.
LG has a way of letting you know if your phone is wet.take your battery out and there will be a small dot circle.when you buy a phone the dot is a blue color.when the phone gets wet it turns pink or red.the best thing to do is when your phone falls into water put it in a bag of rice.the rice will draw the moisture out of the phone.let it sit in there over nite and try in the morning.
Nov 16, 2009 | LG KF750 Cellular Phone
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
Will not power on
Pl. check th ebattery status.
May 09, 2009 | IBM ThinkPad T30 2366 Notebook
Tv locked
Enter all Zeros, if that does not work try 1234 or 9999.
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
Feb 02, 2009 | Quasar SP-3235 32" TV
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
Won't respond to volume or channel changes red light blinks 20x's when turned off.
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
May 11, 2008 | Panasonic TH-42PX60U Television
Buttons not responding.
you need a new keyboard assembly
Aug 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
