Question about Power Acoustik TS1440-2 Car Audio Amplifier
MH master amplifier power light not turning on
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 16, 2008
I have a sony s-master digital amplifier which will not power up: when I plug it i to power it takes about 30 minutes before the red standby light comes on but no other functions operate.
So the standby indicator never changes state? If so, more than likely, your amplifier has DC Offset(a damaged amplifier inside) which will keep the speakers off, and disable any use of the front or remote functions. If you are interested in having your Sony repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Jul 11, 2015 | Audio Players & Recorders
Sony s master amplifier won.t turn on stand by light on .we lost remote
Yo should be able to turn on the unit with the power button on the front panel. What happens when you try this?
Mar 18, 2014 | Sony Audio Players & Recorders
Try to get another remote from ebay.
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
My digital amplifier S-MASTER,mod HDC-SB300 just 5 seconds after I turn it on swithes off by itself and the standby light keeps flashing and the display stays off and i can do nothing..thanks
hi,
may be ur amplifiers any of the output channel have some problem. that's why it goes off after power on, protecting ur speakers. disconnect all the speakers and inputs and then power on it if works check ur speakers and inputs. if not there is fault inside ur amplifier.
ok
Dec 22, 2010 | Sony TA-N9000ES 5-Channel Amplifier
When I depress the shutter button to take a photo the green light turns to red and will not take a photo. New battery. Help?
Red light indicates battery is out of charged.
What type of battery are you using?
the recommended battery for your camera is the AA Ni-MH batteries
now if your using this batteries Ni-Mh and charged it still id did the same thing., How long you already used this batteries more than 2 years now? If yes it means the battery or the Ni-MH is already defective it means that the chemical contect of the Ni-MH is already crystallized and for you to solve it you need to reconditioned the battery or may be purchased a new battery. Gudluck!
Nov 04, 2009 | Kodak EasyShare DX4530 Digital Camera
Interior lights do not come on
Is it an old van? Can you see on the door frame a switch does it come out when the door is opened (push in and out a few times). 3 position switch on always / off always and door switch?
Apr 10, 2017 | 1999 Ford Windstar
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
Power Acoustik TS1440-2 Car Audio Amplifier Logo
43 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
