With cable attachment to my flat screen LCD Tv I have been unable to get a signal with an mmdi cable. Have tried to read and follow the manuals.
  • cmorgjr Jan 16, 2008
    Yes, my bad. 19 in pansonic TV and Sony DVD Player only. Thanks
    Sorry, I am in Birmingham, Al and the new TV and DVD I just left in my condo in Fl. Will have to get the data and try again sometime in the future. Thanks anyway.
  • 1,113 Answers
Can you tell us your model of TV and also models/make of equipment you are trying to attach, what does is a mmdi, I cant find info on it
Posted on Jan 16, 2008
  • 1 more comment
  • Soulvisitor
    Soulvisitor Jan 16, 2008
    do you mean HMDI cable
  • Soulvisitor
    I am going to need the exact models of the equipment (the sony dvd and panasonic 19" flat screen TV) to help you, it will be written on your equipment and on the manuals
    I need the models so I too can see your manual and explain exact prodedure to hook it up for you.
  • Soulvisitor
    Ok I'll be waiting for your future post. All I can suggest at this point is to ensure it is installed fully, sometimes they look like they are in but can go a little further
    Speak soon
    Cheers
RCA 42la45rq no signal issue
Check your cables.
As for VolUp/VolDown Contact RCA If you still have a warranty.
Jun 20, 2014 | RCA 42LA45RQ 42 in. LCD TV
Is there a solution to get enable me to receive a digital signal with this tv
You will have to hook up a regular antenna to get digital TV signals.Then go to your menu and find auto search.This should scan and pick up your channels for you.You can follow this link and on page 44 of the manual,it will explain step-by-step. Good luck :) http://www.lg.com/us/support-product/lg-37LC2RR#
May 27, 2014 | LG 37LC2RR 37 in. LCD TV
Hitachi , L32A01A , LCD, sound but no picture Need service manual or solution to issue BTW. I hate Hitachi. Have a 42 inch Hitachi Plasma (4 years old) screen separation and now the 32" LCD 1 just a...
hi, try these steps...
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
good luck!
Feb 10, 2011 | Hitachi Televison & Video
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
Sound but no picture
Hi.
If an LCD TV has sound but no picture do the following:
Generally, when the screen has no light at all, it is the inverter, rarely the main board.
When the screen is blank, inverter is OK, and it may be any of the other faults listed.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Regards.
Nov 13, 2009 | RCA L42WD22 42 in. LCD Television
I have 40? LCD Samsung flat screen TV model: LE40A557. This is 16 months old. Today the screen went blank and power indicator light blinks. I have switched the TV off and removed all equipments attached. I...
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
Oct 17, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Nov 17, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Protron 42'' LCD TV
If you need to connect to DTV,you must have RCA cable(video/audio cable,could be component video cable and audio left and right!) Also,in order to have that connect it,you need to have a cable box,directv or dishnetwork box that got the component video output. If you are connecting the coaxial to the TV,you are not going to have any signal in the DTV connection,cause there is anything connect it to there!
solutiondoct
Nov 11, 2008 | Protron PLTV-4250 42 in. LCD Television
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
