Question about Kenmore 24032\24036 Top Load Washer
Washing machine spine
My washing machine did not drain or spine it keeps the water inside and ismell asmoky odour it did the washinfg turn well but after the speed of turning reduce
  • 1,314 Answers
You have something jamming your water pump you may have to cleanout the pump and replace the motor coupling Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 16, 2008
Water not spining out
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
There is a bad odour coming from my washing machine
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults', including bad odours, are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Now- if all is OK with the washer, turn your attention to the u-bend and pipes/hoses into and through which the washer water is drained. Check to make sure the odours are not coming from there just in case!
Hope the filter is the problem and good luck!
John C
Mar 23, 2011 | Washing Machines
Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
Happy Holidays
Dec 13, 2010 | Maytag Washing Machines
Machine not spining and the drum inside is not turning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Oct 26, 2010 | Zanussi FS1455W Front Load Washer
Nasty odour coming from inside machine even after numerous cleans with hot water, detergents, vinegar and bicarb of soda.These were done individually over quite a period of time but the smell still...
you may need to remove the inner wash tub and access the outer tub to clean out all the spent soap,detergent,fabric softener that hasn't been drained during previous washes and have now created a sewage mold from just sitting there,also make sure all the drain hoses and the pump are clear and there are no hoses kinked all the way to the drain
Jul 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Not spining and water not draining
Access the water pump and look for plugged drain hoses or a plugged filter as well as a slipping impeller on the pump shaft--or even a dead pump motor. Spin usually will not occur if there is a high water level in the machine. Try draining the tub into a bucket, then see if it will go into spin mode. Hope this helps!
Jun 27, 2010 | LG WM2277H Front Load Washer
check the drain hoses from the wash tub all the way to the drain for kinks or obstructions,then check the pump body for damaged impellers or debris inside such as coins, etc
Apr 16, 2010 | Kenmore Elite 20972
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Bad Odour from Drum
The smell that you are getting is stale soap build up between the inner drum and outer tub caused by frequent use of low temp progs. to remedy this problem do a 90 degree prog with some old towels this will melt the old soap, if you still have the problem add some soda crystals and do the 90 degree wash again failing this your drain hose may be to low causing dirty water from the sink to back drain in to the w/m, raise level of drain hose. hope this is of some help murdozzz
Apr 13, 2007 | Zanussi F1045W Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
85 people viewed this question
Sal De
 Brian Main
Brian Main
