Question about Sony FWD-42PV1 42 in. HD-Ready Plasma Television
Broke tv Why would my tv kick on and off and the screen never actually never show anything because it kicks off so fast?
From what I have read - its a faulty Y SUS board. There seems to be replacements around at USD35 but I have yet to lay my hands on one
Posted on Jun 20, 2008
81 rm125 hard to kick over and slips into gear
Hi Christian it looks like something broke away under the clutch cover. Like a spring or a guide rail. These could affect both the gears and the kick start shaft. You will need to remove the clutch cover to examine further. Regards Jim...
May 16, 2015 | Motorcycles
Cost to fix screen on 42 inch lcd
It is actually easier than most people think. Try taking it apart and see if it is something you could do. Much cheaper than a new tv.
May 02, 2013 | Vizio GV42L 42 in. LCD Television
My kick sound has died out of the kit, when i press the button there isnt a sound so i assume it doesnt have anything to do with the cables or actual bass drum pad. any ideas?
My guess would be something faulty with the cable connector to the kick pad.
Source the faulty link by reconnecting the pad so that:
1. A tom pad triggers the bass drums sound 2. The kick pad triggers a tom sound 3. Don't use cable you use with the kick when searching for the fault.
This should tell you whether it's the pad, the bass drum channel or the cable that is at fault.
Hope that helps!
Mar 03, 2011 | DDrum Kit
I kicked my emichine computer and it broke. First the screen went slightly fuzzy and when i turned it off and turned it back on and it wouldnt show what the cpu was thinking on the screen.What could be...
I would check the components inside the case...sounds like something wiggled loose while you were kicking it. Open the case...first check that all the cards (pci/video/RAM) are properly seated in their slots. Next make sure the hard drive plugs havn't wiggled loose. Post back if it still doesn't work
Jul 18, 2010 | E-Machines eMachines Desktop PC
Kick start broke and case broke
the kick start broke or did the shaft that the kick start bolts to?, if the shaft broke, you will need to remove the case and replace the shaft. as for the case, depends on how bad it broke, some people can weld alum. but i would buy a new case. and then install kick start on new shaft
Sep 25, 2009 | 2004 kawasaki KLX 125
Machine doesnt fill
inlet valve is underneath ..behind the "kick plate" ,,,you need to remove the kick plate to access it ...just look for the water line it conects to the valve ....it would be rare that this is cloged ...it may need replace ment ....make sure the actual water is turned on from your main hot supply ....some times people turn them off and forget to turn them back on ,,,,it's located under your sink
Jul 25, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Broke screen
The mirrors are just mirrors, any paint/glass store can get new ones cut for you if you take the pieces of the old one in. The screen is going to be a hard one though. Actually if you can find (which I am sure you will be able to) another broken tv, very seldom is there any damage to the screen itself. There are two parts to the actual screen though, a tinted piece that dims the picture and a frosted piece that catches the image. Good luck!
Jun 12, 2009 | Sony KDF-E42A10 42 in. LCD Television
Kick pedal for rock band dosent work
I acutually snapped my rock band kick pedal in half and discovered alot about it. The way the kick pedal actually works is with a little magnet thats under the orange part. if your orange bar piece fell of or anything check that or take a magnet and tap the top of the kick pedal near were the wire comes out and if it reacts on the game then theres nothing wrong with the kick pedal just check the little magnet make sure its there. After I broke my kick pedal i went out and cut a piece of diamond plate metal in the shape of a foot and basically made another pedal piece and welded bigger magnet on it and now it reacts on time and alot better it seems cause its heavier. Hope this helps!!
Dec 30, 2008 | MTV Games Rock Band for PlayStation 2
Having prob connecting my laptop to a TV via hdmi
try playing around a bit with the display settings, there are not many laptops that are setup to automatically adjust to the dual screen setup with an lcd tv. Also, iv found that Not using the lcd as a duplicate of the main screen is a good idea, set it up as a separate screen...if you know what i mean, if you do it right you will see only yourbackground on the tv and no start menu bar or icons.... In this configuration you can set the resolution to the max for the best quality possible for your television.
Nov 25, 2008 | Computers & Internet
Sony FWD-42PV1 42 in. HD-Ready Plasma Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
