Question about Malber P21 Front Load Washer
Washer is jumping extremely only when spinning
I have a brand new malber P21 washer which is strongly jumping when hits the spinning cycle
please help
thank you
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Posted on Apr 01, 2008
    President:
  • 1,314 Answers
Well first im not familiar with your brand no hands on experience per say but the most common causes for this is the shipping braces weren't removed at installation second is the washer level and the lock nuts aren't tightened on the leveling legs third is floor is not strong enough to support the washer consult your owners manuel under installation for the location of all the shipping braces and setup procedures if after following them you still have a problem call for service hope this helps
Posted on Jan 16, 2008
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
Service manual need
I have a malber washing machine and it is broken. One day, a loud noise came from the machine then, the machine would not spin out nor did the water drain from the machine. I would like to find a repair place who could fix my machine. I live in Providence, Rhode Island and would like to locate someone local. Can you please help me?
Apr 26, 2013 | Malber P21 Front Load Washer
WASHER WONT SPIN AT FULL FORCE?
Please check the belt and also check the friction of the drum. If this is good then the motor capacitor must checked, you can couple a capacitor in parralel to confirm;
Jun 26, 2012 | Malber P21 Front Load Washer
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Jun 25, 2009 | Malber P21 Front Load Washer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Machine won't run through cycles automaticly
Sounds to me it might be a thermal pause, if your unit is running and then is required to heat up at a certain point and reach a certain tempurature before it advances, the heater is probably not coming on. The unit will therefore not advance.
Sgt 48
Jun 02, 2008 | Malber P21 Front Load Washer
Water fills in and out during the whole cycle but no spin
unplug the machine for 60 sec or more then plug back in this may help this resets the computer good luck
Dec 17, 2007 | Malber P21 Front Load Washer
More details for the washer
this machine have 8 preset washing cycle did you try in other one?good luck
Aug 10, 2006 | Malber P21 Front Load Washer
Hey I got a question about the spin cycle?
need more info I dont understand the question..post back
Aug 09, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
132 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
