Question about Zenith DVP615 Portable DVD Player
Have no manual
I just need some info because I bought this unit used and it did not have the manual with it. How long does this take to charge? I plug it in and the red light comes on for just a few minutes and then goes out.....does that mean that it is not charging fully? I just have no idea of whether or not it is supposed to stay on and then turn green when fully charged or not.....I watched some parts of videos on it, but am not sure how long it really played before I got the signal of low battery on the screen. Thanks for any info you could give me.
  • jbuddyt Apr 16, 2008
    need a manual for my dvp615 dvd player. It won't power up at all using the battery or electrical plug. It's only 6 months old.
Thank you so much!!!
Posted on Apr 21, 2008
It sounds like a bad power cord. Check your cord to make sure there are no kinks or breaks in it. I have that problem where my cat chewed the cord and now the unit cannot charge properly. Additionally, check to make certain the battery is seated properly. Try cleaning the contact with an Q-tip dipped in alcohol. Once you have done that, leave the unit powered off and see if you get the red charge light. If not, you probably have a bad cord.
Why wont my sanyo vc-e760 hold a charge
Since you've already tried different batteries, you have a couple of other options...
  • Instead of plugging the USB cable into the camera's wall charger, plug it into the USB port of a computer, or even into a USB phone charger.
  • Try another wall charger.
  • Try another USB cable.
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
Aug 04, 2014 | Sanyo Cameras
When you charge it does not work
I have the same unit, and I even bought a new battery for it. After the resudal charge on the new battery wore off, it would not charge.
I now use it exclusively plugged into the cigarette lighter. When I need to update the maps, or the software, I use the USB cable.
I am still trying to get the tech manuals on it.
Hope that helps.
Sep 29, 2010 | Magellan RoadMate 1412 Car GPS Receiver
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
I just bought a new laptop yesterday and when i plug in the chager it dont chager it said plugged in not charging so idk what to do thankxs
On the front of the laptop or near the screen you should see a light that shows one color for when it is running on battery and another when it is charged. Usually yellow when charging and green when charged.
As well when you boot into windows near the clock you will see either a battery when using the battery, a plug with a lightening bolt when charging and just the plug when you are 100% charged.
In your user manual you should find a few picture that show and explain where and what all the light or indicator mean. If you go under control panel ot right click the icon near the clock then you get into the power panel.
If you are new to laptops it is a good idea to have the manual open and go over everything to familiarize yourself with what and where. Then you will avoid what I did when I first bought a laptop and couldn't get the wireless to work. If only someone had read manual and saw where the switch was ;-] Enjoy your laptop once you get used to things they are hard to be without.
Nov 04, 2009 | Dell Inspiron 1525 Laptop
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
Need specific instructions on charging the system
<font color=red><B>try the reset on the side of the unit..if you dont know where that is, look for it in your manual,</B></font> <P>
<form action="http://www.magellangps.com/assets/manuals/604-0132-001_A_UM_1212_ENG.pdf" method="get">
<input type="submit" value="click here">
</form>
Jun 21, 2009 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
NAVMAN S70 S Series - is it possible to charge the unit and use it at the same time - when plugged into cigarette lighter in the car and plugged into bottom of GPS unit, the unit seems to assume this is a...
Some chargers will 'fool' the satnav into thinking they're connected to a pc, my S90 was just the same. I bought a car charger on eBay that said in the description "These are purpose designed car chargers so that you can also continue to use your devise whist charging it will not go in to PC sync mode." I bought one of these and it now lets me use the satnav and charge at the same time, whereas my other car charger wouldn't let me.
May 27, 2008 | GPS
Magellan maestro 4040
plug the unit in and press the silver button by the left side and make sure the unit is fully charged if not,plug in the home charger and iti will be fully charged 3 to 4 hrs,also if the battery is fully charged the unit should turn on after you press the silver button on the left side and hold for a few secs. without the car or home charger.also chk your cd manual for further info.let me know what happens.ok.
Feb 27, 2008 | Magellan Maestro 4040 GPS Receiver
Zenith DVP615 Portable DVD Player Logo
184 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
