Question about iLO 2600 Television
Ilo 260tv remote does not work
Tv buttons on tv does not work as well as remote. the power on and off button on remote works but not anything else. so what can i do?stuck on one channel and one volume, loud
  • sho t Jan 20, 2008
    what solution, experts can t even tell me how to fix this problem!
    Genius:
  • 1,139 Answers
This looks to be a problem either on the IR circuit board or in the microprocessor that controls these features and controls. I would suggest since you have tried to change channels from the TV itself that the problem in the processor is the more likelyoption. In this case I would say since this would involve a lengthy troubleshooting procedure, That you may have to take your TVs to a qualified TV repair facility for servicing since the procedure may be beyond just replacing a part, and may involve actual electronics troubleshooting. Having owned a shop for some time I can tell you that some items are only repairable at TV shops.
I hope this helps, Thank you, Shuttle83
Posted on Jan 24, 2008
I found a ilo 32 hdmi t.v. model lct32ha36, there is not a button that says on/off. Just a standby. I want to figure out if it works before I by a remote to test it. Can you suggest anything?
Most new televisions are actually labeling the "power" button correctly. Unless a tv is unplugged, it is never really off. It just goes into a state of standby. This is what you would have called your power button.
Jan 03, 2012 | iLO Televison & Video
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
I lost the remote for the ilo tv and need to get it to video 2 mode in order to play ps3. I can turn the tv on and off and change channels with dish network remote but cannot get to video 2. The "input" or...
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
lone99star
Jan 09, 2009 | iLO 2600 Television
My ilo tv wont work wright
I do have the same problem on my ILO 26HD It worked fine for about a year and sudenly it got freezed, can anyone please find what it is?? Thanks!!
Aug 14, 2008 | iLO 2600 Television
Ilo-32hd
I'm having the same problem. And yes, it's probably from static shock because I shocked the tv when I went to turn it on the other day. Now nothing, it goes on but none of the button work. Is there anything we can do about this? Help!
Feb 29, 2008 | iLO 3200 32 in. LCD Television
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
ILO-26HD
take your tv back to the supplier you bought it from let them rectify the problem.i suppose that your tv is still under warranty.good luck.
Apr 19, 2007 | iLO 2600 Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Ilo 2600 remote control code
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
Sep 09, 2006 | iLO 2600 Television
Televison & Video Logo
53 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
