Question about Dell 2200MP Multimedia Projector
Bulb Exploded As I was using my projector, the bulb exploded. There was loud sound of glass breaking and then a strong burning smell. After the unit cooled, I opened the bulb compartment and it was shattered. Does anyone know why this would happen? I was told that when the bulb goes it doesn't explode it gets dimmer.
  • Anonymous Mar 06, 2008
    my bulb exploded with 25 hrs on it. my question is what hazardous materials was I exposed to? I was sitting under the projector when it exploded.
    President:
  • 4,402 Answers
Did you have the fan on? usually it explodes because of excessive heat, make sure the fan works when you replace the bulb
Posted on Jan 16, 2008
6ya staff
SOURCE:
My NEC lt30 is smoking after installing a new bulb. There is a rectangular, hollow plastic piece that seems to be touching the bulb and smoldering. Is there supposed to be metal over this? Is it part of...
First, stop using the unit IMMEDIATELY. Is the replacement a genuine NEC bulb or knock-off? If it's genuine, they'll replace it. We have had issues with the cement used in the knock-offs in several different projectors. They all work fine at first, but the cement will break-down very quickly, and will let the actual 'capsule' move-around inside the lamp module. The reason I'm serious about not using it, is that we had one capsule slide backwards and melt-into the wiring. That caused the $200 ballast board to fail.
Aug 31, 2011 | NEC LT30 Multimedia Projector
I have an infocus x3 projector and while watching a movie i heard a loud pop and the video went out. It sounds like glass moving around inside the projector. its fairly new and in a well vented room. Is it...
yes try to check the bulb if broken but when you replace the bulb be sure not to touch the glass surrounding because if accidentally touch the glass their will be a mark appearing on the screen.
Jun 29, 2011 | Televison & Video
INFOCUS LP350 WILL NOT POWER ON, SMELLS LIKE A CAP EXPLODED.
did the projector make a popping sound if so that lamp has shattered. the smell would be mercury and the projector will not switch on until the lamp has been reset.
depending if the projector was hot the hot glass may of stuck to the lcd screen so it may not work again.
Feb 09, 2011 | InFocus LP 350V Multimedia Projector
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
Infocus LP530 no power
the power supply needs replacing. sometimes the caps are dried up, but show no signs of damage. when the caps doesn't work, the ps doesn't work.
May 07, 2009 | InFocus LP 530 Multimedia Projector
Projecter went bang, is it bulb or fuse.
Hello. First, unplug the projector. Next, obtain some paper towels or newspaper and make a suitable work surface on a table. Then, open the lamp door and *being very careful here*, remove the lamp. Immediately check to see if the lamp has indeed blown--usually the bulb portion of the lamp pops into pieces but sometimes it breaks the cone shaped reflector. Next, flip the projector right-side up and shake out any broken glass fragments--hence the need for a disposable surface! Then, using a flashlight, CAREFULLY inspect the area in the lamp compartment where the lamp is aimed at to see whether the heat-absorbing glass or glass filters have been damaged by shrapnel at all. (When a lamp explodes, that much force is generated!) If any glass panels are cracked or pock-marked at all, the projector MUST BE REPAIRED before use. These glass panels can, of themselves, violently shatter due to the extreme heat from the lamp.
If no damage in the compartment has occurred, gently blow out any tiny glass fragments with canned air. Put in a spare lamp and see if the projector will power up--chances are it won't. There is an internal fuse normally located very near the power plug socket. It is usually a Buss glass fuse, 5-7 amps rated, but if you haven't worked on projectors before, I wouldn't suggest removing the top cover to get at it...send the unit off to be repaired...When a lamp blows like that, a lot of times it takes out the power supply section and/or the circuit that powers the lamp (ballast). If glass panels are damaged, the "optical engine" (internal framework that houses all the mirrors, lenses, and filters) must be replaced--that is very expensive--some companies are able to fix the optics without replacing the whole engine. Hope I helped you.---Rick
Apr 29, 2009 | Hitachi Performa CP-RS55 Multimedia...
Lamp light blinks
The blinking lamp light indicates that there is a problem with the bulb. Mine did this when I had used the bulb past it's life and the bulb was burned out. Use the owner's manual instructions to remove the bulb and visually inspect it. Mine looked burned out - it was black with clouds on the glass. If this is the case with yours, replace the bulb, or replace the whole unit. (Bulbs can be costly.)
Mar 21, 2009 | Sharp XR-30X Projector
Projector emitting sparks
the ballast blew and needs replacing. if it was the power supply, the led wouldn't be on.
Jan 01, 2009 | InFocus (HW-HTSCREEN76) 76" 16:9 Projector...
Projector quit working and started smoking
Unfortunately your motor is toast- it also provides the low voltage for the remote control. Motors are no longer available new so your best bet is to try to find an old projector on the sued market. you can often get them as cheap as free to $25.00. If it's working, just use it. If there are other things wrong but it's motor works, you should really have the identical motor- not all were the same electrically.
Dec 18, 2008 | Kodak Office Equipment & Supplies
I have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Mar 08, 2008 | InFocus Proxima DP6155 Multimedia...
Dell 2200MP Multimedia Projector Logo
247 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
