Question about Kingston flash memory card - 256 MB - MMCplus Graphic Card
My Kingsto Mini Sd
Dear sir my 1GB kingston mini sd locked up without me making a lock code wat do i do???????????????
  • 3 more comments
  • TheKid45 Jan 17, 2008
    it isnt a side bar is there another lock code i can put into it???
    yes it goes with my nokia 6265i i dropped my phone and turned back on and the card was locked
  • TheKid45 Jan 18, 2008
    thanks
  • Patro1 Apr 25, 2008
    I just takeout my Kingston 1GB memory card from my Nokia 6288 and put it again. after this it is saying Card is locked and asking for password whereas i never locked the card. what I need to do . help me on this
  • beckson Nov 20, 2008
    I done exactly the same and now mines locked with a lot of pics that I want!!
    Genius:
  • 1,067 Answers
Unlock it on side bar then formatt it
Posted on Jan 17, 2008
  • Anonymous Jan 17, 2008
    what did u pull this mini card from a cell phone ?
    thats why u shocked the card its done buy new one on ebay 4 bucks ok
6ya staff
SOURCE:
How to delete pictures in built-in memory, dmc-LZ7
connect your camera to a compter
click start click on computer you should see your camera click to open you should see your pictures on the sd card select the ones you want to delece right click delete
hope it helps
Apr 03, 2012 | Kingston 1GB Secure Digital Memory Card
My memory card is locked
Good day!
Locked..You mean write protected?I think there are instructions on how to unlock it.
Anyway, Try this:
There is a slide unlock/lock switch in the side of SD card. Its up and down switch that on and lock the card.
If you're using a mini card try to insert it to standard SD adapter.\
regards,
Mastergani
Jul 06, 2010 | SanDisk 1GB microSD Memory Card
My 1gb micro-sd card is locked
G'Day vishy
Most micro sd cards from sandisk have a lock switch on the side of the card. First thing to do is check that it is not in "lock". If lock is not selected, then the card itself may be faulty.
regards
robotek
Jun 25, 2010 | Kingston 1GB Secure Digital Memory Card
I want to format my 3110 phone i need a formating code
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
Jun 21, 2010 | Nokia 3110 Cellular Phone
How to remove write protection from sd memory card
On the Mini SD adapter, there is a small lock tap button,you push down usually when you put your mini SD card in to it, then into the USB adapter. To turn off the write protection on your mini SD, simply do not lock your mini SD in its adapter.
Mar 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How can i format my locked micro sd
my memory card wants password but i did not create password in my memory card.so my memory card is locked.how can i solve this problem?
Dec 14, 2009 | Kingston 2GB Secure Digital Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
try mo yung appliction na memorypaswordfinder
May 10, 2008 | Nokia 6300 Cellular Phone
My kingston mini sd
replace it sumtimes it happends when u drop it
Jan 16, 2008 | Kingston flash memory card - 256 MB -...
How to remove write protection in mini sd card? when process in running
I hope this helps - I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!!!!!!!!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now.....don't know why this has to be done, but it works!!!!!!!!!
Nov 09, 2007 | Nokia 3230 Cellular Phone
Open Questions:
Avast Antivirus tEcH sUpPoRT pHoNe @#@[+l855*26O*OO64^] nUmBeR USA Avast Antivirus USA phone number {+l855~26O*OO64^} is ranked Avast Antivirus is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. Avast Antivirus email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Avast Antivirus support number When you are using the Avast Antivirus for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, the user can dial the Avast Antivirus support number and ask for the help. Once you dial the Avast Antivirus customer support number, you come in contact with a team of experts at the Avast Antivirus customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Avast Antivirus support phone number will help you with that simply and quickly support number
Nov 11, 2019 | HIS Computers & Internet
See all Kingston flash memory card - 256 MB - MMCplus Questions
Computers & Internet Logo
82 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Ekse
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
