Hdmi not working on brand new haier hd tv
Conected tv up good picture via scart and pc but hdmi nothing but distortion
  • 3 more comments
  • GTAMAX Jan 16, 2008
    no via x box 360 no signal just distortion eratic sound from game
    no conected via hdmi lead and screen just blue even after reboot of x box and source sert to hdmi 1 or 2 no sound either with or without game in x box
    no luck both hdmi seem not to function scart is ok but poor quality boxed item back up as defective thanks for trying
  • Anonymous Apr 09, 2009
    dear sir
    my haier mob:- m230 model ka battry charger and soft wear ka problem ha.
  • Anonymous Mar 27, 2014
    hdmi scart component not working
  • 4,102 Answers
Are you using hdmi leads and how are you recieving hd are you recieving it through a box
Posted on Jan 16, 2008
  • 1 more comment
  • paul proctor Jan 16, 2008
    are you using the xbox plugged into the telly via scart lead and is the game your playing one you know works.
    Have you tried selecting av on the telly controll to make sure your on the right input channel.
    Also people have been getting problems playing consoles on these tellys when they have things like dvd players plugged in as well if you have got this try removing the dvd scart lead out of the tell then try your console let me know if i got the way you set up right
    so your just using your xbox as normal through scart lead into telly move the lead about a bit make sure the lead isnt damged also have you tried pressing av on telly controll if so some new tellys have a game mode option have a look enter the setup mode on telly controll you can also turn off the blue screen but the blue screen usually means their is no signal going into the telly try using different scart port on telly make sure your on right av channel as their is about 3 or 4 different av channels let me know ok
    if the hd lead is ok and the xbox is ok and you have selected the right hd channel on the telly your telly should pick up the signal as soon as you switch the xbox on it should automatically select the cource but even if you are selecting the hd channel and you are still not picking up the correct signal then the problem is going to be either a bad port on the xbox or a bad port on the telly but as the telly is new its not going to be that so i would look at either the lead being faulty you could try moving the lead a bit at either end just to see if it picks the signal up any better.
    If the lead is new then i would say that the problem is going to be the xbox it might be that the port on the xbox is faulty.
    Try removing the hd lead from the telly then switch the xbox on now put the lead into the telly with the xbox on this should pick up the fead and select the right hd setting on the telly let me know how you get on ok.
    Also on the new samsung telly when you press the setup option on the controll their is a game mode setting this needs switching on as i found out on my telly before the telly will pick up the console depending on what telly you got but i know this is on all new samsung tellys
When I connect the television to the cable I get no signal the cable is brand new and is good connected to another television.what can be the problem?
Posted on Dec 29, 2013
Assuming we are talking about a BRAVIA edition Sony TV,.. I just purchased a KDL-42V4100 LCD TV,.. and it also has spotty or distorted sound on the HDMI circuit. Everything works fine through the basic cable connection or with component wire connections. But on the HDMI circuit, nothing.
After long go around with Sony service,.. they admitted to having a Service Bulletin regarding an update for the HDMI audio circuitry. They are sending out a USB stick with flash update to supposedly fix the problem.
I will keep you all informed whether or not it works.
Posted on Jan 28, 2009
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
Sound problem between bush 47" and v+ via hd
We are having the exact same problem, our 3D tv works perfectly with the V+ box when connected via the scart but when its connnected via HDMI cable then there is no sound at all.
Did you manage to get this problem resolved and if so, how? Thanks.
Mar 14, 2012 | Televison & Video
Picture but no sound via hdmi
Switch your Default audio device to the High Def one. That should fix your problem.
Jan 20, 2012 | Computers & Internet
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How to connect two vcr via scart cable over old tv
what you mean old tv ? with not scart conection?if yes,conect first vrc to second vcr via scart and second vcr via rf cable to tv if no scart socet on tv or via scart if tv have scart conection.
Aug 14, 2008 | Televison & Video
Set up surround sound with the following
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
I bought dvd hdd recorder 3 days ago from lidl it is a targa DRH-5700X seriel no. e5809000859. Imust not have it connected right as i cannot get anything from it on the television.Ihave the recorder...
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
Apr 23, 2008 | Toshiba SD-4000
Televison & Video Logo
2,239 people viewed this question
Top Televison & Video Experts
