Question about iRobot Roomba 4210 Bagless Robotic Vacuum
I robot discovery
My i robot keeps on going backwards and keeps on circling
  • 1 more comment
  • crystalblue9 Mar 23, 2008
    My roomba keeps going backwards. Then it hits a wall or chair leg and rubs its rear edge up and down against the surface about a dozen times, finally making the "uh-oh" tones and stopping. We have to move it from the wall or chair and restart, where it starts to go forward again, then suddenly begins to travel only backwards and "humps" (sorry) the chair legs or walls. I cleaned off the cliff sensors and tried to see if there was lint caught behind them. BTW, mine is the scheduler.
  • sagia Jan 08, 2009
    Same problem my roomba Discovery is in backwards spinning mood my i robot keeps on going backwards and keeps on circling the oh-ha and stop.What should i do about it.
  • Anonymous Apr 02, 2009
    the same thing, my machine keeps going backwards and forwards and spins around!!!
I have takin several Roombas apart with this problem. Basically the sensors on the bumber are blocked so the roomba thinks it is hitting something. I believe this is a design problem because it is so common. If you could see how the bumbers work, there is an infrared sending unit and an infrared receiving unit (they look like little LED's. when the bumper is pressed, a plastic piece moves between the two infrared led's blocking the transmission. This signals roomba to stop and backup. What happens over time is the sending led thing gets dislodged and moves slightly. The receiving led can't sense the signal so it thinks the bumper is depressed.
Hard to explain, but I have fixed the problem by shimming the led back in place and worst case, I drilled the hole in the plastic piece a little larger. Solved the problem and I have recaimed several roombas that were considered scrap. Irobot should fess up to this known problem and issue a fix for everyone of the defective units.
Posted on Mar 06, 2009
  • 126 Answers
This is a very common problem with this machine. It's little electronic brain is in spasm. There is a 1-800 number on the bottom of the machine and will connect you with the manufacturer. They have a fix for it and you should NOT explore further. These electronics are very sensitive and you can damage them very easily.
Posted on Jan 20, 2008
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 goes in circles. appears lost
You have a locked wheel switch that needs to be cleared. You will need to remove the top of your roomba and find which wheel switch is clogged and clear it.
Mar 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Discovery brushes won't turn. All bearings clean.
usually fibre jammed in wheel / brushes. try small hook run around spaces in unit toremove usuall human hair
Sep 14, 2009 | Roomba Robotic Floor Bagless Vacuum
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
I robot won't go forward
Apache Server at www.youtube.com Port 80
May 29, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
It runs mostly backwards, and in circles and will push itself up
make sure you have the battery in correctly plus to plus and minus to minus
Apr 12, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba Discovery 4210 was "played with" by 3 year old
go to roombaexchange.com and send it to them to get it ran through a battery of tests.
Apr 10, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Circles
Do you have it set on "spot"? This causes Roomba to start out in circles, expanding and expanding until a certain time and then returns by going in circles, making smaller circles, until it gets to its starting point.
Oct 21, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
508 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
