Question about Dell 2300MP Multimedia Projector
Dell 2300MP - no power
I can not get any indication of power when I press the 'on' button - on the unit or the remote. I have changed the power cord with no difference. Worked fine one day, the next time, nothing. Any ideas? Many thanks.
Scott
  • MapperDan Aug 11, 2008
    My 2300MP Projector is not getting power. I tried a different outlet but the green light on the power button still does not come on.
  • 2,336 Answers
It looks like you may have a loose contact somewhere around the AC input. Try pushing the AC cord or wiggle it gently, if power comes back on; you have a loose connection.
Posted on Jan 17, 2008
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
We have a dell monitor/tv and the remote control wouldn't work all of a sudden. when we tried to fix the problem, somehow we "locked the buttons" and cannot figure out how to unlock it.
Email Dell tech. support with your issue.
But first try removing the power cord and press and hold the power button on the front face of the unit for 30 seconds..
Remove the battery on the remote and press any key on the remote for a few seconds.
Replace the batterys on the remote and power cord on the Monitor.
Try to power up the unit and see if that works.
The Monitor/TV have a CMOS battery which retains all your setup information. By removing the power and holding the power button, you may be able to clear the memory and reset the unit.
Sep 06, 2009 | Dell Computers & Internet
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
High definition
When i press the power button red lamp indicator on
Feb 10, 2009 | Dell 2300MP Multimedia Projector
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
No power to my dell 2300mp
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
Nov 02, 2007 | Dell 2300MP Multimedia Projector
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Dell 2300MP Multimedia Projector Logo
488 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
