Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi 50UX22B I just cleaned the mirror and the 3 projectors off and dusted everything off with a soft brush. I put everything back together and when anything is in white,Like writing or the tv guide menu on direct tv it is blurry. Can you give me some advice on what to do to fix this problem? Thank you. e-mail is Nicks692002@yahoo.com
    President:
  • 4,402 Answers
Was it blurry before you cleaned?
you should use lens cleaner and a soft cloth on the lens.
TV: Viewing Screen RPTV - damage and maintenance
http://www.hdtvmagazine.com/forum/viewtopic.php?t=6547
Posted on Jan 16, 2008
My TDP-P75 toshiba projector keeps cutting out for no reason - any advice anyone?
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Dec 08, 2012 | Toshiba TDP-S8 Multimedia Projector
My tv is not even shutting off i lose the screen i get yellow flashing light then after a few 30sec to a min then i get screen back, when i go to shut it off i get green light i never got red light ju
Sounds like static electricity caused some damage somewhere...you never want to try to vacuum a TV or use a cloth or brush, only thing that is safe is air like is used to clean a keyboard...you damaged a board in the set, could be the main or tcon or both
Mar 01, 2018 | Toshiba 50HM67 50" HDTV
How to clean a toshiba tv screen model # 50a62
snap off the fron cover its pretty tight so kind of pull hard dont worry it wont break its just snaped on tightly, after uncrew 3 screws under the screen lift up and pull out screen there will be 2 wires attached to screen, unplug them to set screen to side. dust off the projectors with dry rag, then clean mirror with windex or any window cleaning product. u are done cleaning front of Toshiba, put everything back together, then unscrew the bottom back and vaccum any dust balls u will see inside T.V. u r now done! let me know how it went.
Jan 29, 2010 | Toshiba 50A62 50" Rear Projection...
Parents gave me their old Mitsubishi TS-5545 a few weeks ago. Pretty sure something shook loose on the move 'cause when I finally hooked it up and turned it on today the picture is hazy and and the...
You could Start with just Cleaning Mirror and top of All 3 Tube Lenses remove Back and try cleaning out All dust and Dirt with Thin Paint Brush then Remove Front Top and Bottom Panels and then you can Clean Mirror and Top Of All 3 Tube Lenses Then Put Back Together and see what Kind Of Picture you have then! Turn Color Off on Menu See if you Have a Black and White Picture?
Jan 16, 2010 | Televison & Video
Brush roller does not turn on bissell upright
Pull the brush out and pull the bearings off the ends. Clean everything up with rubbing alcohol. Put it back together. DO NOT OIL the bearings. Oil will make dust stick and jam the bearings again.
Mar 10, 2009 | Vacuums
Hitachi 50UX22B
Look inside the lens while the set is on. If you see things floating around inside the glass, the fluid will need to be changed inside of each tube. I will post a link on how this is done if this is a Magnavox TV set. Good luck
Feb 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
DIrtDevil Ultra Handheld - No Suction & Brush not moving
take everything back out and make sure everything looks fine, then carefully put it back in do not force anything or it will bind up.
Dec 03, 2007 | Dirt Devil M08100RT Classic Handheld...
Problem in scanned work
The Reflective Mirror Set in the scanner were subjected to dust. Clean the Mirrors (wipe the Dust with a soft hair 1 inch Brush. Do it under an Expert's Supervision
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
"No Disc" message
Its always a good idea to open it up and look for accumulated dust on the lens. make sure to note where each screw goes, and such. If you see dust on the lense you can brush it off with a soft brush, and give it a damp wipe. If that didn't do anything then the lens mechanism could use a cleaning and oiling, but dont go any further if you're not confident that you know what you're doing, and don't take things apart to a degree where you're not positive that you'll remember where everything goes. I had a "no disc" error recently that was fixed by taking the lens mechanism apart cleaning and oiling it, and putting it back together. It could also be a problem with the motor. Get a repair estimate at a local shop. good luck
Mar 15, 2006 | Panasonic DVD-A115
Hitachi 50UX57B 50" Rear Projection Television Logo
107 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
