Question about LG DLE5977 Electric Dryer
Takes too long to dry
1. air ducts are clear
2. It seems to be heating. I'm not sure if it is hot enough, but clothes seem warm when you take them out.
3. One thing, the "cooling" light seems to be on all the time.
Any ideas?
  • 2,427 Answers
Is the lint vent cleared, Try cleaning it out with a vaccum cleaner, stick it in the hose and where the hose connects too and suck everything out, you can also try sucking out the lint vent,,, Also place less items in it and see if it helps..
Posted on Jan 16, 2008
  • 4,102 Answers
Hi you will probably find that the temperature controll thermostat needs replacing they are relitively cheap to buy but can be difficult to replace yourself if you know what you are doing and where to look for the part you could possibly get your local repair shop to source the part for you but im not 100% sure with your make and model where the part is located on the drier repalcing the part will be cheaper than replacing the whole dryer.
But it all depends how old it is and wether anything else is likely to fail due to the age of appliance.
You will probably find replacing the temperature controll will solve your problem and then you should have no problems as dryer are less likely to break down than say a washing machine.
Let me know what you want to do or if you need further assistance
Dryer functions seem normal, barrel rolls, air is circulating and it feels hot, however clothes are not dry after several cycles/hours.
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Mar 06, 2011 | Whirlpool LEQ9858P Electric Dryer
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
My kenmore elite dryer is only 1 year old and does not seem to get hot and takes long time to dry clothes
Dec 12, 2010 | Kenmore Elite HE4 Electric Dryer
Timed dry dosent seem to work as well. other settings woork but not as well as used too.
Are we talking about clothes not drying ? If we are you need to check your lint duct for a restriction not just the hose behind the unit but all the way to the outside vent.turn on unit go outside to vent should feel a good flow of warm air.Over time these ducts get restricted and it happens slowly then one day you relize its taking a lot longer to dry than it used to.. To dry clothes properly you need more than just heat ,you need good air circulation to remove the moisture otherwise all you end up with is warm moist clothing......Hope this helps Good Luck
Aug 08, 2010 | Whirlpool GEW9250 Electric Dryer
Model (41793042201) Heat in dryer is shutting off (does not stay hot) and clothes are not getting dry.
If heater comes on and then goes off after a while, it is most likely a problem with the exhaust. If not enough air is moved, the element will over heat and go out on it limit, thus protecting it from burning out the element or burning clothes.
Check out the duct to see if it's clogged. I've used a shop vac to blow out ducts and it seem to work ok. Just be sure not to blow the flex duct off the boot.
May 01, 2010 | Kenmore 93042 Gas Dryer
Dryer (electric) seems to heat up initially, then cool off and not get hot enough to dry clothes. What is wrong?
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.(usually located inside the unit on the actual blower housing or inside the vent duct)
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 19, 2009 | Dryers
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt heat up enough to dry clothes
sound like the vent duct going thru the wall to outside is stopped up / check your duct and outside dryer flap to make sure the air is open / if blocked it will take 2-3 times as long to dry and make it seem like the dryer isn't drying / larry
Dec 02, 2008 | Kenmore 62602 Electric Dryer
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
LG DLE5977 Electric Dryer Logo
74 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
