Question about Vivitar ViviCam 5385 Digital Camera
Camera won't come on
We usually use rechargeable batteries and it has worked fine. But lately when I try to turn it on it it just flashes the red light. The batteries are new.
  • 5 more comments
  • Anonymous Jun 05, 2008
    My camera will not come on the atteries are brand new but still i don't get any red flash or anything. I need serious help.
  • blackflash7 Jul 23, 2008
    need major help. I have a vivitar camrea 5385 and it can come on but the screen is totally black. Know wats the porblem?
  • amberpan Sep 01, 2008
    I was downloading pictures to my computer one day when the camera shut off. I figured that perhaps the batteries had died, but when I put in new ones, all it does is flash the red light at me.
  • Anonymous Nov 22, 2008
    THought I'd solved the earlier problem with the camera not coming on because of a design flaw with batteries not connecting and it's still having problems.
  • cbdeluna Dec 02, 2008
    My Vivitar 5385 cant take a picture is totally black. What ca I do?
    Please send me the list of Service Ceter here in the Manila, Philippines.
    Thanks
    My email address is cbdeluna@mabuhaysat.com
    Thanks
    Charina de Luna
  • cbdeluna May 11, 2010
    is there aybody will nswer our questions?
    i guess this company has a bad customer service.
  • 3 Answers
Open the camera and remove the batteries. Use the eraser on the end of a pencil to reach up inside the camera and gently clean the battery contacts. Be careful not to bend the contacts. Don't use a lot of pressure or a lot of scrubbing, just let the slight abrasiveness of the pencil eraser do the cleaning. Use a pencil with a good clean eraser, not one with a dried out, hard, old eraser. Hold the camera in the normal upright position and reach in from the bottom with the pencil, so all of the eraser bits and dirt fall out of the camera. Check that there are no dirt or eraser bits left inside after you are done cleaning.
Clean the contacts on the battery compartment door the same way.
Hope this helps. It fixed my vivitar 5385 that would not turn on, and had the light blinking.
Posted on Sep 04, 2008
Flash stopped working
Your problem is in the settings. Glad maybe turned off set flash to auto.
Jan 02, 2018 | Canon PowerShot A70 Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Hello. My daughter has had her samsung S73 for 3
The eye flashing is normal when the flash is trying to charge up , if the batteries are healthy the camera won`t take a picture until the flash is charged fully.Try turning the flash off and see if the camera fires, get some higher rated rechargeable batteries (2000mah) or above this may resolve your problem.
Aug 02, 2009 | Samsung Digimax S730 Digital Camera
Kodak DX3900 camera can't get power from battery
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Camera doesn't turn on-battery recharge prob?
okayy well when it came out the first time i Grabbed the Lens and held it till the camera turned off and the lens stayed out i blew on it and i turned it on and it worked =)
Jul 26, 2008 | Olympus FE-280 Digital Camera
Blinking red indicator light
Hey pollyannac,
The red blinking light probably means either the flash is recharging, or the camera buffer is full and it is writing files to your memory card which the lcd monitor should read Busy while the camera is writing the files. If it is the flash recharging then you could try using more powerful batteries such as the Canon NiMH AA batteries. If the problem ends up being the camera is writing images to the memory card you could try getting a memory card that has a high write speed. These memory card are usually more expensive, but in my opinion well worth it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot A720 IS Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Camera Turns off and flashes light soon after turning on then freezes
I have exactly the same problem and I found, that it is probably related to rechargable batteries. If I use normal batteries, everything works fine. Confusing is, that I used to use rechargable ones all the time, but errors started few days ago. I also have two sets of rechargable batteries, but both are useless now. Maybe that camera is getting old and it needs fresh 4x1,5V from normal batteries instead of 4x1,2V from rechargable ones.
Oct 01, 2006 | Olympus Camedia C-725 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
127 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
