I have a whirl pool gold dryer /seneon.It use to dry very well in short time and now it takes an extra 60 to 90 minutes to dry.There is no abstructions in the dryer or vent hose all the way out to exit.I noticed in the dark (best way to see the glow coils work)that the heating emements turn off prematurly and takes a while to come back on
I'm having the same problem with 2 sets of stack dryers. There doesn't seem to be a lint buildup that I can see, the gas cycles on and off so it does get hot so I am baffled. I've got the same dryer, home version, at my house and it is 13 years old and works flawlessly. Maybe that is not a valid comparison since these get more use but they are 8 years old. What can I check?
Try putting a vaccume cleaner as far down the vent hose as it will go and suck anythng in there out, , And if you can put a vacume cleaner attachment in the lint trap and suk some stuff out as well ,, other than that i doubth that there is anything else that can cause the problem...
Try placing less items in the dryer and see if it drys ..There could be too much items in the dryer and because of the weight its using too much enegry, so that will cause it to turn of prematurely... If that dont help try changing the coils,, but i douth its the coils ,, its eighter something in the vents eighter the hose or where the hose attachs or the lint vent.. OR WEIGHT ,, as the macing gets older it tends to get weaker so if its overloaded that will cause it as well,, try just putting a few items and see if it worksTry placing less items in the dryer and see if it drys ..There could be too much items in the dryer and because of the weight its using too much enegry, so that will cause it to turn of prematurely... If that dont help try changing the coils,, but i douth its the coils ,, its eighter something in the vents eighter the hose or where the hose attachs or the lint vent.. OR WEIGHT ,, as the macing gets older it tends to get weaker so if its overloaded that will cause it as well,, try just putting a few items and see if it works
You can't post conmments that contain an email address.
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Hello, What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
You more than likely have a buildup of lint in the vent hose. Even what looks like not much lint in there can cause the dryer to have issues drying the clothes. Clear the hose out really well, take it outside and shake it all out, then hook it back up and give it a shot.
If that doesnt work you may have a bad thermal fuse which regulates the dryer temperature and you will need to have it replaced.
Ok, check the exhaust hose for obstructions. make sure the blower assembly is not clogged and, the hose is clear of any debris. the exhaust hose should blow out hot air forcefully. if the force of the air isn't blowing hard, it will not create a suitable drying environment for the element. this poor ventilation will also damage the heating element or burner Assembly.
Now, if there is sufficient air flow out of the exhaust hose, this will confirm control failure. replace the dryness sensor and control board in this case.
Here's a quick way to test for clogs. take the hose of the backside of the dryer then, start the cycle. if the drum sorts to become hot after a few minutes with the exhaust hose removed form theback of the unit, this will confirm a major block in the hose or blower assembly.
The first thing to check on would be your ventillation. Check at the outside of the house to make sure you have a strong amount of airflow coming out of the vent. Should blow pretty hard. If not you need to get your vents cleaned and also make sure the duct behind the dryer is not crushed. Hope this helps. Dave www.washermd.com
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row.
that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up.
When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
