Question about Whirlpool Calypso GVW9959K Top Load Washer
Cl error hi i have an error code ; cl on my LG intello washer ddrive model wdm1480fhd i've tried to turn off at the mains an the machine still remains frozen with this error code & we cant even turn the machine off or re-set it in any way. please help thanks jim
  • Anonymous Mar 07, 2008
    same problem! cl error code.
  • Terybull Mar 23, 2008
    I also have a CA code as of today. The manual states this is a current limit malfunction. "CI" stands for an instant current limit malfunction and "CA" stands for an average current limit malfunction. The manual can be found at: https://secured.whirlpool.com/Service/Sr...$FILE/8178010.pdf
    I replaced the drain pump motor about 4 months ago. I've tried to use the diagnostics test found in the manual ... no help. I'm going to drain it and then take a look underneath.
    The website is awesome and has been extremely helpfu!
  • 4 Answers
From Terybul:
I took the cover off the drain pump and found a penny lodged in it. Please note this is a new drain pump and motor combo that I replaced on the machinge approx 5 months ago. The original pump is solid and you can't take it apart to clean it. If there is a piece of clothing in it, you can try to pull it out. I did this before when I had the original pump, but it never worked the same ... it made a loud humming noise when spinning. I bought the replacement piece off e-bay for about $70. It was fairly easy to install. The new pump is easy to take off and check ... it has only 4 screws. Try to drain the machine as much as possible and have several containers ready to catch the water or you will have a flood ... see note 1.
Before you do all this, check the external drain hose ( the hose from your washing machine to the drain in your wall) was clogged with a penny. The original external drain hose has a valve that keeps water from coming back into the washing machine. On an occassion one year ago, I found a penny that had lodged in the valve and kept it from draining and thus the "FL" code.
Note 1: A good way to drain your washing machine is to take a hose pipe and put it in the top of the machine and then use a manual air mattress pump (in reverse mode) on the opposite end of the hose that you put outside. After several pumps on the air mattress pump sucking the water through the hose, you will create a suction that will keep flowing until much of the water is out of your tub. Be ready with several containers to catch the rest of the water when you take the hoses off the pump.
Note 2: Check pockets well to keep things from getting into the drain system. Use a delicate wash bag (a mesh bag) to wash undergarmets, hose, hankerchiefs, and other thin items that might get sucked into the drain system.
Posted on Mar 23, 2008
Error code cl
LG Washer Error Code Cl Fix. CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it
May 02, 2017 | Washing Machines
What is the error code CL mean for LG WM1285FHD
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks
Oct 10, 2011 | LG WM-2277HW Front Load Washer
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
If this doesn't work then try pressing "options & select" till the light goes off.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG intello washer WM1285FHD The code CL is on display how do i clear and get machine to work?
CL == Child Lock.
Press "Wash" & "Rinse" buttons simultaneously to set / clear.
Dec 26, 2008 | Washing Machines
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG intello WM12235
SE error code means a communication problem between the display controls and the main control board.  You will need a qualified LG technician to locate and repair the problem.
Jun 09, 2008 | LG WM-2277HW Front Load Washer
CL ERROR
"CL" means Child Lock. Press and hold RINSE+ & PRE WASH Simultaneously for about 3 seconds to de-activate.
Jan 16, 2008 | LG WM-1480FHD Front Load Washer
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Jan 06, 2008 | LG WD-16115FD Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal De
