Question about Panasonic PT-47WXC43 47" Rear Projection Television
No Picture Sound is on but no picture..big tubes inside do not go on.
  • Anonymous Jul 11, 2008
    Panasonic, 7 years old. Turns on, but no picture. Audio is on, but sometimes it also goes off. Hear crackling noises from inside.
    President:
  • 4,402 Answers
I would start with the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 16, 2008
Could my picture tube be out ?
plasmas dont have tubes,there are 3 computer boards inside that can go bad,power,control and backlight,contact the company for service
Jun 03, 2015 | HP PL4260N 42 in. Plasma HDTV
Picture and sound went out. quickflash across the screen. then nothing. tv still has power. model number 46ex2b. couldn't find it listed
the problem may be in the heater supply, there are 3 picture tubes in projection tv. remove the back cover, switch on the tv & observe the heaters are glowing inside picture tubes. if not unplug the tv wait for 2 minutes, & trace the picture tubes' heater wires. there may be dry solders in heater power supply.
Aug 25, 2011 | Hitachi Televison & Video
Have sound but no picture. We have comcast and can only see a small screen in upper right corner after pushing the menu button. In this picture, I do see my comcast channels and I am able to change them...
Look inside front panel under RHS picture tube for leaked fluid. If you see a puddle on signal board, take tv to street - it is unrepairable then. The coolant is poisionous.
If that looks ok, then make sure you're using original Mits. remote.
Hope this helps.
Jan 18, 2011 | Mitsubishi VS-50703 50" Rear Projection...
Picture is not very clear and the color is faded and can not adjust it
This mite sound crazy but it is time to change the oil in your TV. Yes your TV has three seperate picture tubes on the inside of it. A red tube, blue tube, and green tube. Each one of thses tubes has a clear oil that the light shines through. Over time this oil gets cloudy and distorts the light thus dimming and fadeing your picture please have a tech change the oil in your tubes.
Nov 08, 2010 | Akai PT4250A 42" HDTV
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Sony Trinitron screen flashing
The picture tube is starting to fail. The increased screen voltage allows it to stabilize at the expense of color quality. Sorry to say, but it is time for a replacement.
Dan
Dec 17, 2009 | Sony Televison & Video
No picture or sound. Buzzing coming from where
Ur high voltage is dead.The FBT the Flyback transformer not prodeucing high voltage.The big black block of plastic with a red wire with a cap hook to the CRT(tv tube).The FBT,must replaced to solved this problem.
Dec 02, 2009 | Televison & Video
Sansui SV 2938 picture disply too big for screen
first is that tv have a tube if it does take back off and you will see what looks like a large light bulb tube and theres a clamp or two maybe even three clamps holding it inside the main big tube loosen the clamps being carefull not to get shocked by touching the wrong thing and the tube will slide back and forth it will also turn so place a mirror or just try looking around it when you adjust the tube to the correct messurement and make sure its level then lightly retighten screws be very carefull not to crack tube by over tightng hope this helped
Sep 09, 2009 | Televison & Video
Sound but no picture is it the picture tube or just another problem
most likely will not be the tubes mate, if the tubes go then you just get a big mix of red green and blue colours in the screen - sound but no picture is more likely to be the starter unit on the flat screen.
flat screens have a starter unit - mine went on a samsung but under warrenty
Sep 08, 2009 | Sony KP-53HS20 TV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
