M-Audio Audiophile 192 Sound Card Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installation of audiophile 192
I put the audiophile 192 sound card into my computer, then when I started it up it just beeped at me and made a grinding sound till I turned it off. Any ideas what could have went wrong?
david mcclellan
Level 3:
  • Master 530 Answers
  • Posted on Dec 03, 2009
david mcclellan
Master
Level 3:
Answers
530
Questions
0
Helped
303331
Points
1839
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
383
Points
Hi, Please install the Audiophile 192 drivers 1st "without" physically installing the Audiophile 192. Then shut down the computer and physically install the 192 and start your computer, Note, this may seem un-appropriate, but is the correct way. M-Audio's Audiophile 192 is a well thought out sound solution with different series drivers, each are applicable to your particular Operating System with more than 1 driver for older O.S.'s Please, if you have installed the card incorrectly ? Uninstall by the advise on there site, which is well laid out and will let you know what leftover files to delete after an uninstall. This method is also used to change a driver to a different revision of driver, read the trouble shooting section to make an informed decision as to the correct driver your O.S. will need so you can enjoy this great product.
Dave Sargent
Level 3:
  • Master 488 Answers
  • Posted on Dec 02, 2009
Dave Sargent
Master
Level 3:
Answers
488
Questions
Helped
170780
Points
1538
Firstly, did you make sure the card was inserted correctly and in the correct slot..? Next, has the card fouled against any other component.? Have you tried removing the card and booting the machine..? did it boot without the card..? Many mainboards are very sensitive to static discharge, did you touch the metal chassis of the machine BEFORE you inserted the card..? Try removing EVERYTHING from the board except the CPU, leave that alone. Now turn it on. If it powers up (it will beep if no memory is installed) start replacing each card or memory stick one at a time and powering up between each one. When the system stops powering up, the last item you installed is the issue. If you get everything back in the machine and it now works fine, you had a bad or corroded connection on something and not necessarily on the sound card. The easiest way to clean the contacts is to remove and refit the card as the connectors will clean themselves if you do this..
Anonymous
Level 2:
  • Expert 121 Answers
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
34036
Points
342
Check that there are no cables near the fan
M-audio 192 it aborts installation Delta doesn't support my system
it supports all operating systems .. the drivers you are installing may be corrupted here is the link below download drivers and install it
http://driverscollection.com/?H=Delta%20Audiophile%20192&By=M-AUDIO
4answers
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Delta won't install doesn't support system
it supports all operating systems ... go through the link given below download drivers and install it
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
My computer is no sound
At first you just load your sound card driver, install it. After installation you must restart your computer and you get sound.
Hey I've just purchased an M Audio 192, Windows XP; with only a very very quiet signal issuing from either my Monitor Outs or the Main Output to my Stereo speakers; I've even tried putting it through my...
you must go into the cmos and diable the onboard sounds when cp starts hit either f1 or f2 or del key to inter cmos be sure not to disable anything else the sound are usly found at the pirephels esxcuse spleeing
Where can i get ibm sound drivers
I want to install sound driver of pentium 4 OPTIPLEX GX260
Low volume
Assuming you are running XP.
uninstall and reboot then restart
device should autofind and self install
Let me know how it goes thanks
Please rate me ,,,Cheers
Audiophile 192 sound card driver
If it hasn't installed the device ,
uninstall device and reboot then restart
Drive d
please put your question again.
is it that you have only C: drive and no more drives are showing ?
Top M-Audio Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
