Question about Haier HLH326BB 32 in. LCD HDTV
  • Anonymous Jul 19, 2008
    hdmi cable is not getting detected by any of my products
5 Suggested Answers
  • 4102 Answers
SOURCE: hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Posted on Jan 16, 2008
  • 2777 Answers
SOURCE: Haier HLH42 wall mounted 2 years old No sound.
Strange, and the DVD is also attached through HDMI then it sounds like, correct? Have you tried switching the ports that the Cable Box and DVD are using on the switch, to see if possibly the port in the switch has gone bad? The good news is it is not the TV causing the issue, it could be just the cable box itself has a failing HDMI output on it.. I've seen this happen numerous times. Most cable companies will just replace the box at no charge... but make sure it isn't the switch, and I suggest you try swapping the cables that the cable box and dvd player are using...
Better yet, just unplug the HDMI cable from the DVD box, unplug the HDMI cable from the Cable Box, and plug the DVD's HDMI cable into the cable box and see if it works... If so it could be just a bad cable, or a bad port on that switch as previously mentioned. If it does work, then try putting the DVD on the other port of your switch and verify...
Something tells me it is the Cable box itself though.
Between all these things you should definitely be able to find out the issue.
Posted on Sep 19, 2010
  • 8909 Answers
SOURCE: do you use a scart lead or the HDMI lead to conect
HDMI would be prefered but scart is fine.
Hope that helps.
Posted on Dec 29, 2010
  • 1637 Answers
SOURCE: 22" Haier LCD/LED TV -
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 16, 2011
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
im not 100 per cent sure but do you have 2 start lead connections (they look like this) 216bed3.jpg If you do, plug the lead into the other plug (in the pics case, the blue one above)
I have to do this with my xbox becuase my tv has 2 plug sockets- one only lets image but no sound, and the other is both. try it and let me know if it works.
Jun 27, 2009 | Microsoft Xbox 360 Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me ( and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Hdmi not working on brand new haier hd tv
Jan 16, 2008 | Televison & Video
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Ps3 using digital optical and hdmi cables together
There is a conflict in the fact that HDMI gives you the digital surround sound without the need for the optical lead and when you allocate the optical for the sound thats when the conflict starts, you can only use one or the other.
Jul 31, 2007 | Sony Playstation 3 (PS3) Console
Haier HLH326BB 32 in. LCD HDTV Logo
46 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
