Question about Dryers
Cloths dryer problem
When put a little or just normal clothes to dryer it trip the breaker. I checked for vibration, 30 amp breaker, voltage 240 volt and wall outlet, cable all okay and it is only 1 year old. It trip the breaker in very short time. Please help
  • 55 Answers
Ok " your dryer should have it's own line, make sure nothing else is pluged into that line.
may have other devices drawing amps.
Posted on Jan 23, 2008
Why does my kenmore dryer not heat up
Why does my Kenmore dryer not heat up.
There are several causes, but the most common one is the heating element. Before we diagnose that lets get down to the rock bottom of basics. An electric dryer runs on 240 volts, like a AC system. So
240 volt systems use two circuit breakers. The heating element in the dryer works on 240 volts. The motor and all the other control parts work on 120 Volts. Just like the other electrical items in your house. So the first thing to do is Check the circuit breaker. A circuit breaker for a dryer has two switches linked together with a cross bar. (or it has two large fuses in which one could be blown) It is possible for 1 of the two switches to be tripped.
Locate the breaker for the dryer. Switch it completely off. Wait 20 seconds and turn it back on. If it won't go on, there is an electrical short in the dryer wiring.
Now we are going to check the heating element. But first, REMOVE ALL OF THE CLOTHES IN THE DRYER. Now turn it on and see if there IS heat when it is empty. If there is IS heat. Then the problem is a clogged, or pinched-shut vent hose in the back. In this case, the moisture in the clothes has no place to go, so it stays in the cloths and they stay wet. If this is the case, pull the machine out from the wall about 8 inches. look down at the hose from the back and make sure it is not crushed. Now see how it dries with the clothes in it.
Let's say it is still not hot. Now we are normally looking at a special white colored fuse that is
mounted inside in the rear. Or a blown heating element that is mounted in the same area.
This repair at this point would normally require a professional technician. BUT if you want to do it, let me know and I will advise you of the steps. Hope this helps,
Best, Mark
Dec 29, 2010 | Kenmore 63942 Dryer
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
Ariston AS66VXNA dryer - everything works but no heat- looking for a schematic to check out and troubleshoot - where can I get detailed schematic?
You can find a manual for your model here>>>>>>>>> http://laundry.manualsonline.com/manuals/mfg/ariston/asl70c_1.html Let me ad that you may have just one side of the 240 volt circuit breaker or fuse set tripped or blown allowing all of the electronic functions, but not allowing the full 240 volts across the heating element. One way is to check the fuse box first and then proceed to measure voltage across the heating element after turning on the dryer. Please use caution while doing this. Ariston Clothes Dryer User Manual ManualsOnline com
Jan 17, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
My maytag neptune eletric dryer is not drying my cloths only cold air circulates. checked continuity of heat element,good, no limits or fuses open, 120volts to each side of the element. What am i missing?
Should have 240 volts at element.  If it has continuity, you will read the same voltage on either side.  Check across the element for 240.  If you only have 120 check for 240 across the two outside terminals where the cord hooks up.  More than likely either a half tripped breaker or defective breaker.
Dec 19, 2009 | Maytag Neptune MDE4000 Electric Dryer
Seem to all of the sudden have problem when dryer gets warm the breaker trips? anyone know why that might be.dryer has been on the same outlet for 2 years.
Hi, When a breaker starts to trip on any appliance, it is drawing more amps then the unit is rated for. It should have a double pole 30 amp breaker if it is a 240 volt dryer.The first thing I would check would be the breaker and the 2 hot wires feeding it. Over the years, the wiring sometimes loosens up due to heat and they may be loose and just need to be tightened up. If you turn the breaker off, it kills the voltage to the wires going into it and you can then tighten them. If you are not comfortable doing this, maybe you know someone that can help you out.Also, overloading the dryer with a lot of cloths will cause the breaker to trip. I am sure that after 2 or more years that you are aware of this, just another cause.You may also have a problem in the motor, which draw a lot of amps if it over heats.You may have a lot of lint build-up around the motor and heating elements that should be cleaned out by removing the back of the dryer. Be sure the power is off before though. Try running the dryer with no cloths in it to see if the breaker still trips.If it still trips, I would say you are loosing the motor, but would check the breaker anyway. Please let me know what you find.
Sincerely, shastalaker7
Oct 31, 2009 | Dryers
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
What size breaker do I need for a 240 volt electric clothes dryer
check on the wiring diagram. You may be looking at 2-15 amp or 2-20 amp breakers.
Nov 12, 2008 | Fahrenheat Electric Convector Baseboard...
My dryer was working fine the other day now it doesnt get hot,and its not drying my clothes
1st thing I always tell people to do is turn the 30 amp breakers off an then back on. Only the heating element is 240 volts, the motor is 120 volts. So if 1/2 the breaker trips the unit will run, but no heat. Try this first. Also depending on dryer if there are buttons for different heat settings make sure the button is all the way in. Some dryers if you hit several buttons at the same time will cause none to be selected and shut down the heat. Hope this helps.
Aug 10, 2008 | Roper Dryers
The heater and timer do not work
The timer won't advance unless te clothes are drying with heat.(No heat, no movement).
Check your fuse or breaker box to see if you have a tripped 30 amp breaker,(Flip breaker OFF then back ON), or blown 30 amp fuse.(Replace both 30 amp fuses to eliminate the possibility of being wrong).
If these check ok,(be certain), then you have a breakdown on the heat side of the 240 volt circuit, at which point, I would recommend calling a technician.
Let me know if I can be of any more assistance.
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
GE Dryer DBL333EAOWW
Did the Dryer work before? What led to this problem? Most Electric dryers work on 240 Volts. And have their own seperate circuit breaker, usually marked as "Dryer." So resetting just the main cuircuit breaker might not be enough. Did you reset the Dryer C. breaker?
Sep 22, 2007 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
