Question about Yamaha Emx88s Powered PA Mixer System
What is the best setting for a yamaha emx512sc equilizer
That would be the main stereo PA Equilizer settings. I am new to the yamaha products. Thank You
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: no stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Posted on Apr 03, 2009
  • 1348 Answers
SOURCE: Hello, simple question. I have a Yamaha R-V702
you are absolutely right
Posted on Jul 18, 2009
tech240
  • 169 Answers
SOURCE: yamaha equilizer is over heating
unexpected heat in electronics can be a symtom of a fault or maybe it not getting enough air to cool, or perhaps just needs a good old fashioned clean, check all the vents if they look blocked or grubby, then
turn it off unplug all the wires and open it up give it good clean inside if it dusty.
If the inside looks spotless, then i am afraid you have a component problem.
Put the lid back on, with enough screws loose to make it safe then leaving the unit with free air round it reconnect all the wires and turn it on, leave it for awhile and monitor the heat build up. Once it is running hot unplug all the wires whip off the lid and very carefully check the different areas inside for heat IT MAY BE HOT IN PLACES. make a note of what you find, even if its just a sketch showing the hot bits.
Then you can talk to a tech/dealer about a possible repair. Suspect areas are the transformer,rectifer,psu dc caps
Hope this helps
Thanks for using FixYa
Posted on Aug 21, 2010
Bose 901's
yaa you can use its best idea but i think you cannot integrate the equilizer into the amplifier settings! it will not give as much effect as you want!
Dec 08, 2007 | Bose 901 VI Main / Stereo Speaker
Using Ipod with emx512sc
Make sure that the Player is set to iPod mode and not AUX.
Jun 08, 2012 | Yamaha EMX512SC Powered Mixer 500 Watts...
Monitors not working on Yamaha EMX512SC, worked once added a keyboard,now we can't get them to work.
Do you mean there is no sound coming from your monitors? Check whether you've accidentally diverted the main-mix signal from main-out (or whatever you have your monitors plugged into). Can you get a headphone mix?Also, dumb question, check that nothing is soloed!
Apr 29, 2012 | Yamaha EMX512SC Powered Mixer 500 Watts...
How do i connect 901 Seriees VI Equilizer to a Yamaha HTR-5790 AV Receiver
Let's try this for a third time. Bose AMP OUT to Yamaha MD/TAPE IN.
Bose AMP IN to Yamaha MD/TAPE OUT.
Please rate this solution.
Jul 04, 2011 | Audio Players & Recorders
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
Every time i turn my truck off the equilizer resets
If you radio doesnt save the stations either when you turn off the truck then it could be your wiring.. For example; Normally you have two power wires.. A red one(Accessory).. and a yellow one(Battery). The yellow one is like the memory.. and the red one powers the stereo when you turn the key. Try switching yours over.. See if that helps. Easily confused and you wouldnt really notice the difference.
Jan 14, 2010 | JVC KD-R200 Car CD/ MP3 Player
No sound from denon 3808.
If you mean by "the multi light" that the MULTEQ XT indicator is on, the AUDYSSEY Room Equilizer is selected. Press the ROOM EQ button (on the main unit) or EQ (on the remote), cycle through the choices and set the equilizer to OFF. A level of -32.0 db in the Master Volume Indicator (top right) is pretty low and the sound may be inaudible in your setup.
Sep 06, 2007 | Audio Players & Recorders
How can I save the 5-band equilizer settings?
The firmware upgrade that might have resolved this problem is no longer available
Feb 27, 2007 | iLO (2 GB) MP3 Player
Yamaha Emx88s Powered PA Mixer System Logo
140 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
