Question about Compaq Presario 5000 PC Desktop
Over partitioned at startup i get a screen giving me a choice of win 98\ win pro or win pro (again)! the one i run is upgrades to sp2 Q= how do i get rid of the other two?
    Champion:
  • 207 Answers
I think the only way you can get rid of is to reformat your other partitioned disk..use your installer to execute them.ok? but before you that, make sure you have backed up some of your vital datas you have.ok?
goodluck!!
Posted on Jan 16, 2008
HP dc5000 compaq - running win xp pro sp2 and it won't upgrade to sp3. Sp3 needed to run Nero 11.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
Aug 24, 2012 | HP Computers & Internet
PCTel HSP56 micromodem not working with Win XP - SP2
just try to download a driver version that support win xp sp2
Nov 23, 2009 | Directv PCTel (56k micromodem)
Getting a Blue Screen after upgrading with Win. Vista Business Upgrade from Win. XP Pro.
Restart the computer is Safe Mode (press F8 when booting to get a menu of options). This will start the computer with the minimum number of drivers and "extras" being loaded. From here you can press Win+R to bring up the Run command and enter 'msconfig' and press Enter. From this tool, you can allow your normal startup programs and device drivers to load. You will want to keep anything related to your DSL drivers disabled for the time being. Then restart the computer normally. If everything loads as it should, you can keep going back to the MS Configuration utility to add other drivers and programs one-by-one and retest (reboot again) to make sure everything is working properly. Once you know what the culprit is, you can uninstall that program and reinstall the Vista version if required. (If it is just software for your DSL modem, it probably is not required under Vista.)
Apr 14, 2009 | Computers & Internet
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
Nov 18, 2008 | Biostar P4M80-M4 Motherboard
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Compaq Presario 5000 PC Desktop Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
