Question about Yamaha RX-V995 Receiver
Yamaha Rx-995 System will power on for a second and then power off. I can see the fan starting to run and then shut off and power goes off too. Checked the fuse and replaced the same still have the same trouble.
  • 1 more comment
  • Anonymous Mar 19, 2008
    Press the switch button, it powers on for less than one second and then power off. Do not know what it goes wrong. Any expert can advise which portion it needs to be changed?
    Same Problem. Cannot Switch on and hold it on
  • Math_E May 04, 2008
    I have the exact same issue... chech everything that I could.... has anyone come up with a solution... or cost to repair???
SOURCE: Yamaha AV Receiver RX V-995
You may have a problem in the primary stage in your Power supply !! Unhook everything that is attached to it .... make sure the power plug is in good shape and you have the right amout of ac at the plug and good grounding ... then then try turning it on again ....
Does it stay on ??
if not .. there is something wrong probably in the primary stage of the Power Supply ... could be a bridge or something like that
hope this helps
Posted on Feb 29, 2008
  • 236 Answers
SOURCE: yamaha receiver model rx-v550
it is your protection circuit working, preventing the unit from any further damage to circuitry. you can check first your speaker cabling for any short connections, possibly red/black terminal wires got entangled. if all ok then try removing all speakers then turn on the amp. if still does the same thing turning off then you have a problem with the amp output stage, shorted power output transistrs/driver probably. if the unit turns on normal without the speakers then you must have one or both of your speakers busted. by the way this amp is multi channel, after removing ALL the speakers connected, and does not turn off anymore, put the speakers back one by one and observe if the unit with turn off and on which set of speakers. otherwise if still trips even without the speakers, it is your amplifier that is deffeective, any of the five channels, main, rear,center. let me know result so i can guide you on how you can get it repaired and what will be the extent of damage in case.
reden
Posted on May 22, 2008
SOURCE: Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Posted on Jun 24, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
SOURCE: Yamaha RX-V2400
Had same problem. Display would read, "Check Speaker Wires". Rear speakers were shorted by a carpet nail. Works fine now.
Posted on Dec 28, 2009
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
I have a yamaha, natural Sound Av receiver RX-V483, every time that i start the unit it will shut down after 5 seconds. thank you very much
It indicates an output load problem, dis-connect the speaker wires from the back of receiver. Next power on and turn the volume right down, if the unit runs, check for shorts in the speaker wires and speakers. But if it still shuts down "with speakers and wires dis-connected" one or more of the audio output ic's is shorted and will need a professional to assess the item.
Feb 02, 2011 | Yamaha RX-V463 Receiver
Yamaha RX-V1600 shuts down in seconds
Your Yamaha RX-V1600 has an audio output transistors are mounted to a large heat sink which keeps them cool during operation. They are electrically isolated from touching the heat sink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set).
You need to check or replace the transistor that's on the heat sink. Or you may contact a pro to replace it for you.
Mar 14, 2010 | Yamaha RX-V1500 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Yamaha RX-V690 powers up and turns right off??????
Hi...
All the speakers are connected at both ends?
If so, you have a power amp electrical break.
Not an easy fix.
Jan 14, 2009 | Yamaha RX-V690 Receiver
Yamaha RX-V995: Remove On Screen Text
Here is a dumb try :). Connect your video source directly to the TV/projector, bypassing the receiver from inserting any messages.
If you are probably going to HD sometime, you would need to do that eventually as 995 doesn't have HDMI/Digital Video switching.
Nov 19, 2008 | Yamaha RX-V995 Receiver
Does it stay on ??
hope this helps
Feb 29, 2008 | Audio Players & Recorders
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V995 Receiver Logo
290 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
