Question about Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive
250GB harddisk only 130GB
I have a "Samsung SpinPoint P120 SP2504C" harddisk. It is 250GB on it.
But a year after I bought it, i formated my harddrives. and then it was only 130GB, in total. please help me. It's a little not fun too have over a 100GB to short.
Thanks
  • 1 more comment
  • Strikewinder Jan 17, 2008
    I tried your suggestion, and at partition magic, it was also showed 130GB total :(
    Thanks for trying though. I appreciate it :)
  • Strikewinder Jan 22, 2008
    Ok... I have tryied som recovery programs and stoff... but only trial's so nothing could fix it... but when I check partion magic now... it show all 250GB :D... but I have to buy it. Is there a way to get me 100Gb back without paying?
    Thanks
  • Strikewinder Jan 23, 2008
    I got all my 250gb now :)
    I also figured out that xp has a maximum of 137gb on a partition, but with service pack 2, that problem was taken care of :)
    Thanks very much for all your help cosisf, I really appreciate it :D
    And thanks too fixya for having this page :)
    Scholar:
  • 176 Answers
Try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Posted on Jan 16, 2008
  • Cisf Jan 17, 2008
    u may also try to go at the BIOS setting, and see if it\s capacity is limited there(some BIOS's allow this kind of settings ) ; and u can also try to use a data recovery software, and make extensive investigation with that software, witch may tell u if there is a damage and where (or if there are marked bad sectors), and even try to fix it ...
  • Cisf Jan 22, 2008
    they are a lot of programs that manages partitions, many free, keep on looking ....
    if u don't find them i'm sure i'll get around paying .... :-$
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
I need a sp2514n hard drive
http://www.amazon.com/Samsung-SpinPoint-P120-SP2004C-internal/dp/B000BONHS2/ref=sr_1_fkmr0_1?ie=UTF8&qid=1265381348&sr=8-1-fkmr0
this link will solve your problem..
plz give vote and ratings..
Feb 05, 2010 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Is my hard drive broken? Cant get it recognised on other PCs
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Dec 10, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
PC Doctor error code Failed SMART Test Error Code HD521-2W
This is in an HP PC? This error (like most SMART errors) is indicative that your disk is on its way out. Your best bet is to buy a new disk quickly, and get important information off this one! SMART errors are usually fairly accurate, though occasionally disks go on for years.
(SMART = System Monitoring And Reporting Technology)
Jul 12, 2009 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
I have the same HDD but system does not recognize the full size
hi there this is because of  unpartitioned disk space i.e, you wouldnt have partitioned rest of the memory while installing OS you would have only partitioned only 130gb tat is the reason it shows tat much :)
u create a partion then u will be able to use memory for its fullest :)
Apr 29, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Hard disk problem
your hard disk is developing bad sector (it will be dead) so better to backup your data
May 17, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive Logo
500 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
