Question about Toshiba e-Studio65 Copier
Sharp sf-2540 copier f1-00 code.
Can you tell me what this code means, thanks
    Problem Solver:
  • 14 Answers
If your machine has a sorter it may be caused by the wiring harness that goes to the sorter from the machine being pinched. Try powering down the machine and unplugging the sorter and powering the machine on. If your problem goes away it is a sorter issue if not it may be a problem in the fuser.
Posted on Jan 17, 2008
My sharp SF-2540 it has a code H5-02
its an error code for the fusing unit
Sep 06, 2016 | Sharp SF 2540 Copier
Sharp 2540 code f2
F2 mean toner not supply .Change toner chip
Jul 12, 2014 | Sharp SF 2540 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How can I reset the password/ Copying code on SF 2540 copier
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Error for sharp SF 2540 H4
H4 means; Heat roller low temperature detection. This is an error in your fuser and you will likely need to get a service technician to take a look at your copier.
Sep 15, 2010 | Toshiba e-Studio65 Copier
Sharp SF-2540 FI-06 error code
looks like a shift error. This is the part that offsets the pages at the exit. See below.
Mar 29, 2008 | Office Equipment & Supplies
Sharp SF-2540 copier error code FI-06
The F1-06 error is = Paper exit drive overloaded in sorter. This means that the exit unit is not driving/ turning properly/ fast enough. This could be that the motor is going bad, exit sensor is bad, drive belt is bad, paper or forgn. ( staple, paperclip, .ect...) in stuck in that area. If you do not have the proper wall voltage, could cause this problem.
Check wall voltage, check exit area for torn paper, paper clip, etc..., check exit sensor and actuator, check belt for wear or broken, check motor ( is it turning/ running) and then controller brd.
Mar 29, 2008 | Toshiba e-Studio65 Copier
Sharp sf.2540
Press C - interrupt - 0 - interrupt - flash
and then
14 and press start
Feb 26, 2008 | Toshiba e-Studio65 Copier
Toshiba e-Studio65 Copier Logo
331 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
