Compaq intel pentium 42.8ghz512mb
IM on laptop, but my main pc wont switch on ive changed the fuse but nothing
  • lillyflies Jan 16, 2008
    thankyou for your help tried all above but still nothing.it lights up and the fan in the back spins half a turn then nothing
    Problem Solver:
  • 13 Answers
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Posted on Jan 16, 2008
Need a manual for a Compaq CQ58 Intel Pentium laptop
In the top bar or you can download complete as a pdf :)
http://www.manualslib.com/manual/491999/Hp-Cq58-200.html#manual
Feb 23, 2015 | HP Compaq Cq58-252Sa 15.6-Inch Laptop...
Can get the battery out of my compaq cq58-252sa laptop
On a jammed switch for the batt on the (old) compaq I would take in for repair so is not you the done that damages anything around the battery casing.
Mar 21, 2013 | HP Compaq Cq58-252Sa 15.6-Inch Laptop...
Driver audio HP compaq presario SR5350F pc Intel pentium dual core
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 25, 2013 | HP Compaq Presario SR5350F Desktop PC...
Ive got a old pentium 4 with ms-6747 ver 1 m/board. when switch on nothing happens,on screen no signal. 1 long beep 2 short beeps
Please refer to the following web site from intell for beep codes and their meaning.
http://www.intel.com/support/motherboards/desktop/sb/cs-010249.htm
good luck and don't forget to vote!!!
Sep 28, 2010 | Intel Pentium 4 530 3.2Ghz PCI-Express...
Dual core cpu on the compaq evo n610c
none im sorry to say but the intel pentium m 1.6 is similar to a dual core it is like a 3.2 pentium 4 in a laptop with 2mb cache i have the evo n610c and it is the best processor i found compatible and it does not heat up like the pentium 4 processor does allowing it to be tweaked a little if you max out your ram and know a little about modifying your pc for any more questions or concerns feel free to call main street pc in plymouth nc (my company) google it and i can get the processor and install it for you pretty cheaply
Mar 09, 2009 | Compaq Computers & Internet
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Dc7100 sff power supply
Part number :
349987-001 Switching power supply (340W) - 100-240VAC input, 45-66Hz
Aug 24, 2008 | Compaq dc7100 Small Form Factor (PJ361UA)...
Speakers
run-devmgnt.msc
check there is audio driver install ya not try to reinstall again
go run -sndvol32 check there is enable/disable if not working your hardware problem call log on HP
Thanks
sanju
Jun 27, 2008 | Compaq Presario Notebook
Audio driver for compaq presario c700 intel pentium dual core
i want audio and viedio drivers for compaq laptop
intel pentium dual core please send my mail
May 17, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
