Question about HP LaserJet 3330MFP All-In-One Printer
Printer/scanner making a hunting sound will not function
In the past few months the machine began making a hunting sound and stopped functioning. I would turn the machine off, wait a while and turn it back on and it would work, at least for awhile. Now, as soon as I turn on the printer, it begins to make the same sound and the display shows: scanner bulb warming up, except that it does not stop making this sound and it will not function.
I contacted HP support and they told me to REINIT FFS, which I did. It didn't work and they then suggested to restore factory default. This did not help either. Any suggestions on how to get my multifunction working again?
    Problem Solver:
  • 13 Answers
The scanner assembly is bad. Even though it is big, it is not that difficult to replace. Google C9124-60103 for part
Posted on Mar 05, 2008
Error message "check connection" yet the printer works wirelessly.
If printer driver was shared from one of the pc, only the printing function can be used. For scanning functions, all PC should be installed direct to the network/wifi printer. Disable all sharing for this printer for the group.
Sep 12, 2014 | Brother Network-Ready Wireless Color...
Hi, My office fax machine will not send or receive faxes, or make copies. I recently replaced the toner cartridge, and then the problems began. It keeps saying either printing online, or sending online,...
Sounds like a glitch in the memory has left a document there, unable to print. You'll need to clear it out by going into the Maintenance Mode. Maintenance Mode is not mentioned in your user's manual, because there are several functions available that can seriously disable the machine. All you have to do to be safe is follow these instructions to get into the mode, clear the memory, then get out without messing around with other functions.
Press these keys in rapid succession:
* (the star on the dialing keypad)
Do that whole sequence in 2 seconds or less, ignoring all the beeping the machine will assault you with. It's designed to not allow some to accidentally enter Maintenance Mode; if you wait for the beeping to stop, you'll fail, left in some part of the normal menus. When you succeed, the word MAINTENANCE will appear on the display, and all the lights will flash in unison. If that doesn't happen, just touch the STOP button and try again.
Once in maintenance Mode, touch 91 on the number pad. The display will say Initializing or something like that as it clears all the documents form the memory. Your programmed phone numbers and settings will not be affected. When it finishes it will go back to MAINTENANCE. Unplug the power for a few seconds, then plug it back in. The machine should be fine and ready to use.
If Function 91 doesn't work, you should try going back into MAINTENANCE and touch 01 instead. It will clear all memory back to the point it was when you first unboxed the machine. But I think 91 will take care of everything.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
Hp 6110 scanner making noise i can do any thing else because of that scanner light doesn't move, move little on scanner glass then come back on right hand side and keep making noise some time i can see...
If you cleaned the scanner glass before the problem began, it sounds like you messed up the homing strip underneath the glass. The scanner is trying and trying to find its home position and it can't. There is no way to disable the scanner to use the other functions. This is the downside to All-in-One machines. If one function (most commonly the scanner) stops working the entire machine won't work. I own a Cartridge World ink refilling store and I always caution people against buying all-in-one machines for this reason. It sounds like you'll need to buy a new printer, unless your printer is magically still under warranty you could call HP and ask what they can do for you. They'll probably just recommend you buy a new machine anyway.
Feb 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
The scanner bulb goes back and forth about an inch in hp 3330 prt
The scanner blub mirror needs to be cleaned and possibly the underneath side of the scanner glass. The scanner is not finding the marks to make it function correctly.
May 15, 2009 | HP LaserJet 3330MFP All-In-One Printer
Machine won't print
Scanner failure means that the scanner bulb is no longer working. There are a few things that can sometimes bring it back but it may be a permanent issue.
1) Make sure printer is directly into the wall and not a surge protector or power strip
2) Remove cartridges from printer
3) Unplug power from back of printer and wait 30 seconds
4) While printer is unplugged press the # and 6 keys and plug power cord in. Keep holding # and 6 until the printer has either powered off or it says semi-full reset
5) Go through initialization process - if it works great the issue with firmware is fixed. If not then the scanner bulb isn't functioning and you are looking at replacing the unit.
May 11, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
"CLOSE BACK COVER", over and over-back cover IS closed.
You have the wrong driver loaded. or your driver has been coppurted. Uninstall and reinstall drivers and software. Check to make sure you have the right drivers first.
Good luck
Mar 16, 2009 | Brother MFC-5440 Printer
Cannon MultiPass C5500 fax machine
turn it off
unplug it
wait a few minutes
plug it back in
turn it on
try printing to it again
Feb 17, 2009 | Canon Office Equipment & Supplies
Try scanning from the Kodak AiO Home Center software. If that fails, you should get better feedback. Unfortunately, I have run into this when my ink is low. While it should not matter, is does. Check to see if you need to replace a cartridge.
Good Luck.
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP LaserJet 3330MFP All-In-One Printer Logo
106 people viewed this question
Ben Johnson
