Question about Sanyo PLV-Z3 Multimedia Projector
Sanyo Z3 "Predator effect" problem
When hdmi upconverting to 720p (with Oppo 981 player) approx 1 hour or so into a movie, the picture will suddenly change to a distorted multi-colored image much like the alien's p.o.v. vision in the movie Predator. The projector is locked up, remote will not function, and must be shut down manually with the power switch on the unit. This does not occur at 480p. After powering back up the image is fine...until it happens again. It is possible that this occurs at the discs layer change, however I can't verify this. Web searches show this to be quite common among Sanyo Z3 owners.
  • know nothing Jan 27, 2008
    How do I hook up digital cable to my projector? Do I need a VCR of DVD player? I tried to hook up cable to a dvd and didn't get a connection. Signed clueless
  • Rodimus Apr 05, 2008
    My Z3 does the same thing - not every time but regularly enough to be annoying. I have found any other solution than what you mention. My latest problem is a blue stain that has appeared on the right side of the image - I'm guessing the lcd panel is going. While I have enjoyed going to a projector not so sure I will buy another Sanyo.
  • 43 Answers
Hi there, Ive recently FGixed a PLV-Z3 was as chas said, Filters needed to be re-aligned.
Ive posted the schematics I used on my site.
http://www.entwan.netau.net/1_2_Repair-schematics.html
Posted on Oct 08, 2009
I just hooked up my Memorex MVBD2535 Blu-ray player to my Sanyo DP50740 plasma bia an HDMI cable. The picture flashes on and off, and sometimes the screen says "no signal". I know the Sanyo...
I had this exact same problem after setting this model DVD player up. I put in a disc thinking I would listen to the movie while working on some other projects and would call tech support in the AM.
Putting in the disc fixed the problem. If there is a disc in the system, I do not have this issue. If thee is not, it does the same thing while it is on.
Jan 04, 2011 | Memorex Televison & Video
How to get full 720p resolution
is that with a dvd player or cable box
unless yuor using an upconverting dvd player you will only get 480 I
if your using a cable box you need to have your cable company come and turn it to 1080 or 720 which ever you want
Dec 07, 2009 | Vizio GV42L 42 in. LCD Television
DVI-HDMI not working with Sanyo Z2
HD comes as 720p and 1080p - the Sanyo will cope with 720 but not 1080 full HD - check the specs in the manual. You should have a DVD output setting for screen mode.
Sep 07, 2009 | Sanyo PLV-Z2 Multimedia Projector
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
I have a 720p HDTV. If I buy a BluRay DVD player with is see a significient difference in my movie picture quality. Im using an Upconvert player now.
I've never seen an upconverting DVD player that could match the image quality of a high-definition disc player, particularly when you're outputting to a larger TV. The basic issue is that the maximum resolution of DVD is 720x480 while Blu-ray is 1,920x1,080. The Blu-ray image is much larger and made up of more information than the DVD image.
You didn't mention the size of your TV, but anything over 32" and high-quality picture is important to you....go BluRay. Not to mention that BluRay are relatively inexpensive now.
Jan 06, 2009 | Televison & Video
Component Cable
Are you just using the yellow cable at this point, because the quality would in fact be awful? Using the green, red & blue cables (component cables) would not improve quality much, seeing as the yellow video cable has a resolution of 480i and component cables are set at 480p. Your TV (if it is in fact high definition) would either run at 720p or 1080p depending on what the manual says and what the native resolution is. I would say try and buy and upconvert DVD player and make sure to get an HDMI cable to go from the DVD player to the HDTV (some DVD players come with this cable, but you'll have to look around for them, otherwise look on buy.com or something for some cheap ones). HDMI connection and the upconvert DVD player will improve picture quality significantly.
Apr 23, 2008 | Televison & Video
DVD Upconverters???
Greetings jhays82,
Some DVD players can upconvert DVD signals to resolutions that match those of HDTVs, and send them to a compatible TV via a digital video connection. HDMI (High-Definition Media Interface) and DVI (Digital Visual Interface) both offer high-quality digital transmission of standard- and high-definition video signals. HDMI can also carry multichannel audio, and is backwards compatible with DVI (video only). So in other words, to receive the full benefit from an upconvert, you would want to hook it up with HDMI or DVI.
Thank You,
Agent Dort,
Go Ahead. Use Us.
Apr 14, 2008 | Televison & Video
Help!
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Apr 06, 2008 | Televison & Video
Maximizing screen resolution/settings for movies? I have had this since new
Hi there
There is no way you could push it any further than 480p
If you would however like a better picture you can add a scaler like the DVDO Iscan VP30 to the mix and be blown out of your shoes with colour and smoothness of image.
Feb 17, 2008 | Optoma EzPro 739 Multimedia Projector
Sanyo PLV-Z3 Multimedia Projector Logo
296 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
