Question about Canon Pixma MP450 All-In-One InkJet Printer
Hi, my canon pixma mp450 is not feeding the paper thru properly.
It gets stuck on the right side and then the printer just thinks it's done printing and doesn't even come with an error code. I'm just past my 1yr warranty so customer svc recommended I take it to a repair facility.
I just wanted to check on here to see if there's a simple solution.
Thanks, any advice would be appreciated.
Kim :)
  • 1 more comment
  • Anonymous Jan 20, 2008
    The paper jams on the right side of my Canon Pixma MP450. I've cleaned the paper feed rollers but that didn't help. There is no error code and sometimes the printer doesn't ask to feed the paper again; it thinks the print job has been completed. The unit is less than one year old. Any advice you can give would be appreciated.
  • my3pearls Jan 27, 2008
    I just got my printer back from the repair shop....paid $75.00 for them to find a metal hair clip stuck inside the printer. They said I probably wouldn't have been able to get it out myself because of how far inside it was, but I sure wish I tried. Just thought I'd post for anyone with the same issue. Something to consider.
    Thx and good luck :)
  • albice Feb 01, 2008
    I have the same problem. Paper gets stuck on right side. Isn't feeding properly. Sometimes printer continues to print as if paper is fed and sometimes it gives a paper jam error. There has to be a simple solution. Help!
Pixma 450 wont' scan
Posted on Jan 03, 2010
We had the same problem so we opened the screws up at the back, gave it a shake and suddenly a asweet wrapper appeared. We then put the screws back in and it started printing again! Good Luck!
Posted on Feb 15, 2008
  • elie1970
    elie1970 Aug 26, 2012
    100/100 you saved me from buying a new printer and + i had about $100 worth of ink i just bought ...thank uuuuu.
  • elie1970
    give it a shake upside down and see what comes out it worked with me again and i save all that ink i had bought that i wanted to thru away with the printer.
I had the same problem - didn't believe something was stuck inside, but i unplugged it, out came a tiny dead bug and now it works again! feel dumb that i didn't try that weeks ago & lived without a printer!
Posted on Jun 12, 2011
  • elie1970
    you are wright but i found a very smal rock my 2 years old put there.
Same problem. Disconnected everything and turned it upside down. Something (undefinable) game out and the printer works again!
Posted on Aug 28, 2008
When my conon(pixma mp450) connect to power it show error no.6500
Posted on Jan 26, 2008
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My canon pixma mp450 printer is displaying an error 5010
This is a carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 02, 2009 | Canon Pixma MP450 All-In-One InkJet...
When I try to print docs from the web, the printer feed the paper but it get stuck after pulling eigth of the page. Copies are OK to print without problem
Clean the paper feed tray
and adjust the tray
Clean the paper feed tray with damp cl;oth
reset the printer to factory default settings if still does not work
....Go thru the manuals how take printer back to factory default settings
Sep 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
The printer wont pull paper thru
theres a piece of torn paper stuck in the feed path. i used to be a photocopier tech and that was a very common problem. get out a flashlight and a pair of tweezers...
Jun 18, 2009 | Canon PIXMA MP160 All-In-One Printer
I have a Canon Pixma MP145 showing error E2. There's paper in the printer. After I turn it off then back on when the cartridge gets over to the right hand side (at the end of the back and forth thing it...
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Jun 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Feb 21, 2009 | Canon Pixma MP450 All-In-One InkJet...
Printer paper reloading
So the feeder woek sometimes, If you have a warranty, bring it back, if not , the printer might have something stuck in his mechanism or a bit of spread ink, open it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean
then try a recommanded paper for the printer like 80g for example and no more than 30 new pages to begin.
You can test the printer when open, you just need to push a few switch or button to make it run also you will be able to see where the noise come from.
Dec 18, 2008 | Canon Pixma MP450 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper isnt loading correctly
My printer does that too, after many copies have been printed out. There is this mechanism that pushes the paper forward and another to slide one paper in... well it won't get in. I tried to add "grease" at the right side, "facing the printer", of that mechanism that made contact to the rollers which slides a paper in..  well my printer now works fine
Mar 19, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
2,061 people viewed this question
old marine
old marine
