Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Duet Washing Machine GHW9200LQ. not draining water showing door lock
Door was locked and water remain inside. Ii all happened suddenly. I turned it off, pulled the breaker for 10 min and reset it - same thing
Any ideas??
  • Reyesr Jan 16, 2008
    Broken impeller blades!!! that was it. Thank you. Good job !!
    President:
  • 1,314 Answers
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Posted on Jan 16, 2008
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
F20 error
If you remove the bottom panel, there is a drain plug and that would allow it to be opened. There is lots of water there though
Jan 05, 2014 | Whirlpool duet Washing Machines
I have a Whirlpool Washer, Duet, 3 years old. I have had the washer stop withour being finished with the cycle. None of the controls would start it, the door was locked, and the error showed an F 21...
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the filter out and clean it You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Here is a video to show you how it is done.
Oct 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Door is lock on my washing machine with cloth inside, what do i need to to?
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Kenmore HE2 Plus Front Load Washer
Due to power outage can't get door open on Whirlpool Duet front loader washer. With wet towels inside, need to manually open door to get them out. Is there an easy solution?
On that type of washer the door lock is wired in series with the water level switch and if water remains in tub the door lock will not power up and unlock..what you can try is (if havent already done so) is select the drain/spin only cycle and when the water has drained the door should unlock
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Model # GHW9100LW on final rinse and spin water remains in washer, door locked and humming sound comes from machine....pause/cancel will not unlock door or start new cycle... what might be the problem?
Sounds like the pump is trying to drain the water but something is clogged in it or the pump itself is bad. Door wont unlock if machine thinks there is water inside. Remove front lower panel. pump is in center. Unscrew cap and remove attached filter. Be prepared for water to come gushing out once filter is removed. Clean filter and reinstall. If problem persists then the pump itself needs to be replaced.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
did you try running a drain and spin cylce? there might be water in machine still and thats why door not unlocking..Assuming theres no water in machine( youcant see any waterline though glass) you can remove the bottom cover (3 torx 15 screws) UNPLUG UNIT. reach your hand up approx six in. on right inside face of unityoull find a manual release for the door lock assy, round tab mounted to bottom of latch assy approx size of a quarter, give it a pull and door will open,might be a fluke that it lock but i would check for operation before filling with close again
Feb 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
365 people viewed this question
Dan Webster
Dan Webster
Sal De
