Question about Dell Latitude D600 Notebook
Video out I'm making sure I know how to attach someone's laptop to our Board Room's projector. We are working with a Dell Latitude laptop running Windows XP Professional. I know how to turn on the projector and attach it to the laptop, but how do I activate the video out so that what appears on the screen appears on the projector? Ctrl-F8?
  • sandycwb Jan 16, 2008
    I phrased my question badly. I can get the projector working and hooked up to the laptop, but I'm not sure how to get the laptop to transmit the contents of its screen for projecting on the screen.
    Do I hit Ctrl-F8
I have
The OPTOMA by HP is a model EP721.
The laptop is also a HP Pavilion dv6000.
The S is Windows XP with SP# 1 -3.
When I start up the laptop I can see the beginning of the Sign-on , namely
Windows XP screen.
But when I am at the desktop I see none of it via the DLP against the wall
screen, but the DLP is lit and I can see the blue background and the
searching.
In the control panel I have both monitors activated.
A few months ago I used this same DLP and the same laptop and had no trouble
at all. Watched a Power Point Presentation then.
But this time I just cannot image what is wrong.
Your help is appreciated. Thanks in advance
Posted on Oct 27, 2008
You may already have your problem solved, but I just had the same issue today and I thought I would post. I did all the steps, but could never get my document to display from the projector until I read that the computer and projector have to be off before you connect the cable between them and connect the projector's power source. When I turned them off, connected, then powered back up, everything was displayed by the projector just fine. Hope that helps you. Cheers.
Posted on Jan 17, 2008
    Champion:
  • 207 Answers
Try to reconnect your cable of your projector just make sure that well-fitted on the port and screws are intact then to try to restart your laptop.ok?
if still doesn't work.just let me know!!
Posted on Jan 16, 2008
Dell latitude D630 wont recognize projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Notebook
I cant get my projector to see my dell d630 laptop ? which f buttons do i press ?
Hold down the FN button and as your doing that push the F8 key. That will force the laptop to use the output on your laptop so your video can be shown on a lcd monitor but it should also be able to be used on a projector. Make sure the settings on your projector are set properly as well.
Dec 18, 2009 | Dell Latitude XFR D630 Notebook
My dell latitude d830 does not connect to a projector. I press the function key and the f8 key simultaneously and the laptop does not connect to the projector.
you hold FN and tap f8, and it SHOULD switch. You can try using any external monitor to see if it works. If another monitor works, it is not the machine, but the projector. you can also check the bios to see if the vga port is enabled, or, check your video driver to ensure it is enabled.
Oct 26, 2009 | Dell Latitude D830 Laptop Computer PC...
When we r trying to connect the dell DLP front projector 1800MP model to dell latitude D830 laptop, unable to connect as nothing displaying the projector. please help me out with the solution
May need to hit Function+F8. This is Dell's standard button for pushing video out different sources, such as the VGA / DVI connectors in the back of your machine. You may also want to start with a "standard" screen resolution, such as 1280x1024 to make sure the projector can handle it.
-J
Oct 21, 2009 | Computers & Internet
Latitude d505 won't display image through projector. Being used with Sanyo plc XU41 and Promethean board. Board is interactive but no help if there is no image to see! Other Dell laptops work with this...
Dell laptops normally have a 3-way toggle for the display destination: 1=screen 2= external display and 3=Both. To toggle from one mode to the next press hold the 'FN' key (lower left corner of the Key board), and the briefly press the 'F8' key. Wait a few seconds for the hardware to catch up and you should see a display through the projector. If not, repeat the 'Fn' + 'F8' combo again.
You could also try running diagnostics to verify that teh video card is working properly. To do that, sthar with the laptop off. Hold the 'Fn' key down while you press the power button. Release both as the machine begins to boot up. It should start in diagnostics mode. Run the quick test and watch for the color bars. If you see then, the video card so=huold be OK.
Good luck, And please let me know how it turns out for you.
~ Spoem
Oct 01, 2009 | Dell Latitude D505 Notebook
Dell 1209S Projector "Searching for Signal" with Laptop
Try fn + f8, then wait and see if the projector detects the port (15 seconds or so) if no change, try Fn+F8 a 2nd time
Jul 28, 2009 | Dell Latitude D800 Notebook
Dell latitude laptop-freezes after running for a few minutes/sometime on start-up/screen on but no response /fan stops running and nothing responds
Im assuming its a C64, these notebooks have overheating issues.
1. make sure the fan has room to breathe, and is clean of dust.
2 Dell Inspiron/Latitude/Precisiion fan control utility will help cool your processor ... http://www.diefer.de/i8kfan/index.html
Jun 04, 2009 | Dell Latitude C640 Notebook
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Cannot project movies in powerpoint
I have encountered this same problem once in the office when i was trying to do the same thing.
The solution:
*Assuming you have windows xp*
1) make sure the projector and the laptop are connected (FN+F8), do a right click anywhere in your desktop then go to settings by default Monitor 1 would be your Lattitude D620 and Monitor 2 should be your projector, to make sure of that click on the 'identify' it should show a 1 in your laptop and a 2 on the projector
2) now select monitor 2 and select 'use this device as my primary monitor' check mark, by doing this your videos should play in your monitor but they will be a blank/black screen on the laptop (basically we are reverting the order).
Sincerely
McVerick
Apr 20, 2008 | Dell Latitude D620 Notebook
Dell Latitude D600 Notebook Logo
233 people viewed this question
Alun Cox
