Question about Toshiba 1360 Black and White Copier
Toshiba 3160 copier
WhenI use this copier the top half of the copy looks great but the bottom half looks like its trying to copy twice, any ideas
  • myarmoral Jan 16, 2008
    when I use this copier Toshiba 3160 the copies that it puts out are bad. The top half is great but the bottom half is dark and looks like its trying to copy it twice, any ideas
  • 417 Answers
Would you say that the bottom half is Ghosting? if so then the fuser hot roller teflon has worn and will need replacing.
If not please check the optical mirrors (Do not remove them only remove the top glass) for dust.
Sorry cannot be anymore help as you may possibly need a engineer call out.
Thanks J
Posted on Jan 16, 2008
Bottom of the copies are darker than the top I
There may be spilled toner inside the copier, Free the drum and paper way of toner an ensure the toner container is not over full. do proper cleaning and the copier will be okay.
Jun 10, 2010 | Kyocera Mita KM-2050 Printer
Toshiba 1360 B/W copier - top half is blank
if you watch closely on the right lower side of the machine you may see that the lower jam access cover is opening during paper feed-this normally indicates that the feed clutch is staying on for too long-remove clean and hope.
Feb 05, 2010 | Toshiba 1360 Black and White Copier
Half looks great but the other half is gray scaled has been getting worse for about a month
1)So, your copie is half with good black color, and other half light, with possiblle white streaks?
IF YES: you need to clean the laser unit and replace the toner cylinder cleaning blade, also check the drum unit - if it got over 25000 copies change it too.
2)So, your copies are half good and half like no toner is fixated on paper?
If thats the case replace fixing roller and bushings, and check the press. roller bushings.
Feb 01, 2010 | Canon USA - COPIERS - ImageRUNNER 2010F...
I have black strip running top to bottom of copy. Machine has 65,520 copies on the counter
What type of copier? A professional grade or SOHO AIO? Check the glass where the copies take place, including where ADF copies, make sure there are no debris. If you can look to see if there are any debris or faults in the scanner assembly. If that's ok it could be many things. If it is a higher end copier it could be as simple as dirty corona wires or as bad as a worn drum.
Dec 18, 2009 | Toshiba 2060 Copier
Copying anything comes out sketchy
I replaced the black ink cartridge....alls well
Mar 22, 2009 | HP PSC 2210xi All-In-One InkJet Printer
Toshiba 35A44
check the verticle stage
electrolitic capacitors
and the verticle IC
Sep 04, 2008 | Toshiba 35A44 35" TV
Bottom half of pgbk band doesn't print
First try doing a deep head cleaning or two; if that doesn't work, try removing the printhead and looking at the bottom of it to make sure there is nothing blocking the small ejection holes on printhead, reinstall the printhead, do the alignment again an that should do it, if not you may need a new printhead.
Aug 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
Install [color] toner
Try cleaning the 4 connectors - and the connector on the machine. Sounds as the though the information about the cartridge is not getting through to the machine. Use an electronic contact cleaner !
Feb 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Toshiba e studio 150 problem
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
Nov 19, 2007 | Toshiba e-Studio150 Copier
Toshiba 1360 Black and White Copier Logo
104 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
