Question about Canon FAXPHONE B740 Plain Paper Bubblejet
Need your assistance please
The other day in the middle of receiving a fax, the cartridge made a popping sound and the display said to replace cartridge. I have replaced it but now it says to check printer. Can't find my owners manual.
    Genius:
  • 1,003 Answers
OPEN COVER OF FAX AS IF YOU ARE ABOUT TO INSTALL INK CART YOU WILL SEE A BIG SILVER BAR THAT THE INK CARTRIDE TRAVEL ON.
APPLY a couple of drops of 3 in 1 oil to the top of this BAR close cover and turn fax machine off and back on then fax should start working again
Posted on Jan 17, 2008
6ya staff
SOURCE:
Our copier (model x5650) stopped while receiving several pages , and displayed FAX IN MEMORY COLOR AND BLACK INK CARTRIDGE NEEDS REPLACED. I installed a new black cartridge , however the display...
YOU NEED TO LET THE PRINTER RE-ALIGN ITSELF AFTER INSTALLING PRINT CARTRIDGES, THE PRINTER SHOULD HAVE PAPER IN IT TO DO THIS, THE TEST PAGE PRINTED WILL THEN NEED TO BE PLACED IN THE PRINTER ON THE GLASS, PRESS SCAN, THIS SHOULS RESET YOUR PRINTER.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Lexmark C533DN InkJet Printer
Message in display: Cartridge error refer to
Here are the basic reset instructions. See also here.
Please make sure you followed these instructions to change the cartridge, and the alignment was completed. (see also here)
It may be necessary to clean the cartridge contacts as described here.
If that does not help, you may also access additional online support for your printer here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | HP Officejet 4315v All-In-One InkJet...
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Wrong cartridge message pops up and won't print because of it
Even with new cartridges sometimes the pc board that is attached to the cartridge can get dammage,replace the faulty cartridge.
Jan 07, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
New crt
Hi there. This message on a Canon fax means that the ink is low. CRT stands for cartridge. Replace the FINE cartridge, as ink is low.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jul 02, 2008 | Canon FAX-JX200
New crt?
CRT means cartridge on a Canon fax. The FINE cartridge needs to be replaced.
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
Canon FAXPHONE B740 Plain Paper Bubblejet Logo
77 people viewed this question
Clive
Clive
old marine
old marine
Ekse
