Question about Baby Gear
Change spark plugs in a 04 6cyl santa fa
How much trouble is it? some one told me part of the intake has to be removed.
  • 77 Answers
It isnt that hard realy you just have to make sure that you take them out in a crisscross patteren and be sure to mark it one through 5 and put them back in the same order
Posted on Feb 16, 2008
Change spark plugs on a 2003 santa fe
That is what you have to do on a chrysler v-6, also-remove the intake manifold. Be sure and use a new gasket for the manifold. Also check if there is a holding bracket for the manifold on one side or the other, or both as on a chrysler.
Dec 18, 2012 | 2003 Hyundai Santa Fe
I changed the injectors, spark plugs, plug wires, intake gasket, and my santa fe 2001 idles good but dies on accelleration
How many km are on this car I would go to muffler shop and do back pressure test it only costs 10$ to me it sounds like a bad cat to me
Jan 08, 2012 | 2001 Hyundai Santa Fe
How do you access the rear spark plugs on a 2004 Sante Fe 6cyl?
You have to remove the intake plenum to access the spark plugs. That's the piece that sticks up and completely covers the back side when looking from the front. If you have fairly average car repair skills, it isn't all that hard but does take a lot longer than a normal spark plug change-out. If you remove the plenum and do this job yourself, you MUST replace the intake plenum gasket or you will end up with a bad vacuum leak. I strongly recommend you refer to a maintenance manual if you attempt this procedure. There is a lot of stuff attached to the plenum that has to be removed.
Feb 25, 2011 | 2004 Hyundai Santa Fe
I need to change spark plugs on my 2004 Hyundai Santa Fe/3.5 V6, can't seem to locate the other 3 plugs. I know they are somewhere in the back of engine compartment. Don't want to start ripping parts off...
you arent going to want to hear this but...you have to remove the intake plenum to access those rear plugs. doable but not a fun job for a novice. rear brakes should be easy if youve done brake before
Nov 30, 2017 | 2004 Hyundai Santa Fe
I have a 2004 Hyundai Santa Fe with the 6 cyl. engine. I wanted to change the spark plugs. I can get to the front ones easy enough, but the back ones appear to be under the intake manifold. How would I...
don't take the manifold off....... see if perhaps the window wiper dip tray will be enough room to access the rear plugs.....do not remove intake.
Apr 26, 2010 | 2004 Hyundai Santa Fe
I need to replace spark plugs and wires on my santa fe v-6. Do i need to remove the intake manifold?
There may be an engine cover over the valve covers that is a big piece of plastic that may say Hyundai, or Santa Fe,
I believe its three or four 10mm retaining nuts that hold it on, take that engine cover off, and there should be 3 wires in the top of each valve cover, those big wires are the spark plug wires, and they actually connect to the spark plug which is down inside the cylinder.
To remove, you will need a 3/8 drive ratchet, a long extension, I would say 6-12 inches, long enough, but not too long, and a 5/8" spark plug socket.
Take one of the spark plug wires out, and put your long extension with the spark plug socket on it down into the hole that the big wire came out of and you should find a spark plug at the end of the tunnel.
Oct 04, 2009 | 2004 Hyundai Santa Fe
Changing spark plugs - need to remove intake manifold and should change gaskets...which ones?
To change a spark plug. 1.Disconnect the wire attached to the spark plug it would be wise to do only one at a time! 2.Take a long socket that will fit the spark plug 3.Attach to the socket wrench and turn counter clockwise until off. 4. Put the new spark plug in and hand screw until tight then turn the socket wrench clockwise until completely tight usually 1 1/2 turns. 5.Then reconnect the spark plug wire. Easy as that. Repeat steps 3-5 for the rest and remember ONE PLUG WIRE AT A TIME!
Sep 02, 2009 | 2005 Ford Escape
Hyundai Santa Fe 6 cyl and spark plug robbery?
On the 2.7 V6, you have to remove the surge tank from the intake manifold to gain access to the ignition wires and the spark plugs. 2hr job.
Jun 26, 2009 | 2007 Hyundai Sonata Limited Sedan
What is the
Yes, the upper plenm needs to come off to change all the sparkplugs,
and use only the factory spark plugs! Do not use any aftermarket plugs or wires on this vehicle
Aug 25, 2008 | 2001 Hyundai Santa Fe
Open Questions:
I'm I dropped my necklace inside my 2018 Camry XSE & I finally saw it today a few weeks inside the lining of the drivers seat belt buckle. Can you tell me how to retrieve my necklace? Thanks! Denise My necklace is inside the lining around the "stem?" Of the seat belt buckle down inside a hole. It's a white gold necklace but appeared to me that it's laying on top of something silver? Possibly some type of track inside the assembly. Honestly I have no idea what I'm talking about. I was excited when I saw it since it appeared as though it could be easily retrieved and it doesn't look like it's very far down inside the lining of the buckle either, so since I have tiny hands I thought I might possibly even be able to get it out with only my hand. Sadly I was mistaken. Next I took some thick, heavy craft wire; first thing I thought of bent it over & made a hook on on end? I'm no fisherman but it seemed that logically it should work? I should be able to catch the chain in the hook. With the fabric of the lining being a charcoal color, inside the lining even darker. Inside a dark car with only an over head light, trying to hold a flashlight while necklace fishing in over 100 degree temps, though I'm stubborn and didn't want to. The heat did finally convince me I had no idea what I as doing and the chances of my catching my necklace at that point much less actually reeling it in safely were probably few and far between. So I'm back to searching the internet yet again. Ha! If you're wondering why I'm going to such lengths to retrieve a necklace, I bought it the day my first grand baby was born and it has her name and birth information engraved on it. It's the sentimental value for her DeDe that makes it so special and why I want to get it back so badly. I'm very much appreciative of anything you can advise me to do to help me with this process. Thank you so much, Denise Tallant a/k/a Stella James's DeDe
Sep 24, 2018 | Baby Gear
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
