Question about Brother MFC-8460N All-In-One Printer
Scanning Problems When I try to scan the machine sends the note "Sending Error" and it beeps I think 4x. We are low on toner, could that be the problem? Please let me know at your earliest convenience.
  1. Machine Error
Posted on Sep 25, 2008
Fines not sending to email
try to scan it one by one as your scanner and processor is somewhat slow or defecxtive
May 17, 2013 | Canon imageRUNNER 3225 Black and White...
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
Mar 21, 2009 | Brother MFC-7420 Laser Printer
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Paper has dark marks down middle
If you make a copy, does the copy have dark areas down the middle of the page? If so, remove the toner cartridge and gently roll it around to redistribute the toner inside, maybe even replace the toner cartridge if you've had it a long while. If you still see unevenness, you may need to have the machine looked at.
If the copies you make on your machine look fine, then I would suspect that the person sending you the fax has a dirty scanning element. Check with them to see if they can clean the scanning element and it should improve the fax quality.
Oct 23, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Feb 07, 2008 | Canon FAX-L200 Plain Paper Laser
Brother MFC-8460N All-In-One Printer Logo
435 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
