Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips 37PF7320A 37 will not turn on
My Philips 37PF7320A 37 , purchased in Dec. 2005, will not turn on. It does not react to remote at all. if I use the switch on the TV itself, the little green light comes on for a second or two and then I hear a click and the red light comes on and keep blinking. Nothing happens after that. What is the bast thing to do?
Best Regards,
Tony
tniedzwiecki@rfmd.com
  • 92 Answers
Moswt of these i have come accross is either an SSB(small signal board) or a logic board. in rear cases it even requires the replacement of the panel unfortunety ther are a number of test that need to be done on the unit to figure which one it is and i dont recomend you try them yourself.
Posted on Jan 20, 2008
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips model 37PF7320A won't turn on
The power supply regulator section is not working properly. It will be best to replace this board as card basis rather than trying to make it right. Philips have used some special numbered components there, which are very difficult to get from open electronic spare part market. Contact the nearest authorized service center for Philips to buy a new board.
Aug 24, 2012 | Philips 37PF7320A 37 in. HD-Ready LCD...
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
37PF7320A 37 problem hooking up dvd
Connect the DVD to the back of the set on AV2 red white and yellow rca cable . Then to the other end to the DVD red white and yellow. Turn the DVD on and press play. On the tv remote below the number 7 there is an AV button. Press that button and put the tv to AV2. Your DVD picture should be there.
Jul 04, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv turns on has sound but picture
Rest the tv by unplugging it from the wall for a hour. If the picture is still gone replace the small signal board.
May 30, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Problems with your Philips 37PF7320A 37 in remote control
If the remote has been replaced the IR receiver could be bad. Try changing the channels with by the tv. Most likely that is the problem.Beside that the small signal board could be an issue. But I would the IR receiver would be first.
May 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Remote control stopped working
Hey. I paid the $20 for the expert advice and (I feel such a fool) I just had to unplug the tv and plug it in again for everything to work!
Martin000
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
230 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
