Question about Mitsubishi VS-60707 60" Rear Projection Television
Tv flutter Ihave a Mitsubishi 60" rear projection TV model VS60707 that at first took about 10 minutes of the picture fluttering before stabalizing to a clear picture. Later it took longer and now I can have it on all day and the constant fluterring does not stop. Is it worth the repair since it is not HDTV capable, although I paid top money for it back in 2001
  • Mitsubishi Master
  • 8,617 Answers
If your going to do the repairs yourself you can probaly get by fairly cheap, but service techs usually run between 3 and 6 hundred for video problems sounds like a capacitor issue. If you need a service manual and unlimited support for your set go to this link. Its 10.99 for the manual the supports free. They will mail it unless you return to the site and request that they email it along with the instructions on how to obtain the chat support. I am one of their support Techs, Hope this helps.
http://servicemanuals.vstore.ca/
Posted on Jan 16, 2008
6ya staff
SOURCE:
Tv flutters
Sounds like a high voltage prolbem. I would look at the deflection board part number A1302180A
Apr 14, 2014 | Sony KP-51WS510 51" Rear Projection...
Tv flutters then shuts off
Sounds like a high voltage problem, I would look at the defelction board part number A1302180A
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
