Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Water leaking from bottom. what's up?
Water leaks from bottom. hot water dispenser works, and will leak after testing that too. how to fix?
  • Anonymous May 06, 2008
    My digital Italia I bought at starbucks leaks from where the silver hose attaches up inside the machine. It is the water line to the steamer/hot water spigot I think. Big water puddle under the machine when I am done although it makes coffee just fine. Need to know where to send it for repair!
  • garthpro Nov 22, 2008
    I don't use my italia much in the warm months. so just started this month(ie something plastic cuold have dried out) when i fired it up last week, it started to "HISS" after the brew was done. Shut down. A few hours later, I walked in to find a puddle under it.
    Any thoughts?
  • 3 Answers
Http:// Check the diagram. Could be one of the internal plastic hoses. One of these caused the leak on mine.
Posted on Nov 29, 2008
  • 2,039 Answers
The best thing to do open the machine cover go easy when the cover is off visual look you probably got a disconnect pipe if not activate the machine be carefull you got live power in there try to make a coffee you a clear pipe black hose connect to it probably dry rubber hose if its that put everything back and clean the machine with a decalcifier block pipe with calcium buil up pressure inside if you have a dry hose its gonna pop off dont forget to rinse the machine very good after that stuff is very corosif if it help you dont forget to rate this cheers
Posted on Jan 16, 2008
Sylvania SE80094-1 hot/cold water dispenser faucets leaks.
It could be a build up of minerals from the water holding them both open. You will need to gain access to the water valves to clean their surfaces.
Jan 24, 2014 | Freezers
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
Water leaking from bottom of quick and hot dispenser only 18 mos old
I had the same problem. There is a 2 piece metal tank inside. The top and bottom of the tank are connected with screws & nuts, and there is a rubber o-ring between the two pieces. The grove for this o-ring is very shallow and it doesn't fit tightly, increasing the probability of misalignment during the assembly process. I was unable to fix the leak, IMHO the grove is too shallow and the o-ring is not thick enough. I decided it was poorly designed & trashed the unit.
Aug 26, 2011 | RTO Waste King AH-780-UL Quick&Hot Instant...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
GE Profile TPX24...water leaking from under freezer side...water dispenser works fine, but ice maker not working properly. What could be the problem...and how do I fix it?! Thanks
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Jun 14, 2009 | GE Profile TPX24PBDCC Side by Side...
Slow leak drips from bottom of 4 year old model
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Fan not working and sides are still hot
For your water flow problem and leak; Check in back of the refrigerator bottom right side facing the back. You will see two plastic tubes, one is for the water dispenser and the other is for the ice maker. Check for a loose connection at that point for the water leak.
May 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dispenser leak
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Dec 21, 2007 | Refrigerators
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
326 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
