Question about 2wire 2700HG-B Router (2700HGB)
Xlite this is the problem i am trying to make calls with the xlite program and the program tells me that is ready and has my user name and ready to call but when i try to maka a call tells me that the call failed: forbidden. and my operative system is vista maybe that is the problem i dont know and the router is a 2wire 2700hg please help me out this is for work.
  • 51 Answers
The key to making this work is to ensure that the Use Local IP Address option is checked in the Topology tab. It has something to with the xlite SIP settings and not your modem
Posted on Feb 15, 2008
Nec electra professional 1 change name?
Name change is program 4-18 in system programming, but very rare for the user to be familiar with that. Call your vendor, maybe they'll walk you through it. On newer systems it is a user function, Speaker, 700 gets you in there if your codes are at default.
Jul 10, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Only rings 3 times then transfers to another ext.
Mitel call forwarding is a double-edged sword. It can be controlled by the end user via user-programmed forwarding and it can also be controlled by the system programmer via system call rerouting. User programmed forwarding OVERRIDES system programmed 1st alternate, but does not override the 2nd alternate reroute destination (if 1 is programmed). Try un-forwarding the phone - if still no joy then contact the system support person. Hope this helps. (User-programming commands are initially defined by the system support people when the system is initially installed, so I can't tell you how to do it... you'll need to know what the key commands are (or unforward using the Superkey function if provided).
Dec 13, 2013 | Mitel Lands Phones
Switched to workgroup for my lenovo laptop - now can log in
are you loging in onto the network? if so you'll need the network user account name and logon
if you know the logon name and password make sure your logging in to the computer user profile not the networked one.
typically the user name is Administrator. 2 accounts are created admin and guest, though most the time Guest is not activated.
if your really outa luck Try a program called Ophcrack :]
either use it as a bootup disk or run it google it sourceforge!
Sep 04, 2009 | Computers & Internet
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Have a z708 lexmark printer can't instal to my computer have no instalation cd
  1. Uninstall any previous versions of the driver:
    1. Click on Start, Programs (Windows XP: All Programs).
    2. Go to the Lexmark folder and select the Uninstall program.
    3. Follow the prompts to continue the uninstallation.
    4. Restart the computer when the uninstall program is finished.
  2. Log on to the administrator account (generally the first account that is set up on the computer). Note: If you have purchased a ready-made system and did not install Windows yourself, you may need to contact your PC manufacturer to find out how to log on to your system's administrator account as this will differ from system to system.
  3. Install the printer again using the latest driver software. Note:
  4. Before you start downloading the software, make sure your printer is on and connected to the computer. If the software requires you to remove your cable during installation, it will prompt you to do so.
    1. Create a new folder on your desktop and call it Lexmark.
    2. Go to our Drivers and Downloads center.
    3. Note: The name of this site/page may be slightly different in your region/country.
    4. Click Printer Driver.
    5. Select the Related Product Name from the drop-down menu.
    6. Select your Operating System from the drop-down menu.
    7. Select the desired Language from the drop-down menu.
    8. Select the latest Driver File and click on the File Name to detach it to the Lexmark folder on your desktop (see step 1).
    9. Once the download is complete, open the folder and double-click on the file.
    10. When the WinZip Self-Extractor screen appears, click on When done unzipping file open:<the printer file name>. (The name will appear beneath this option).
    11. Click Unzip. The installation program should autorun. Follow the on-screen prompts to install the printer.
    12. If the installation program does not autorun, double-click on the newly created LXK___ folder for Setup.exe. An installation program will run. Follow the on-screen prompts.
    13. If you are prompted to install the printer for all users, click Yes.
    14. When the installation is complete, restart the PC.
  5. Try printing from the administrator account first and then from the user account that exhibited the problems in the first place. Both should print to the printer.
  6. If the administrator account works and the limited user account does not,
  7. click here for additional information.
Sep 16, 2008 | Lexmark Office Equipment & Supplies
Belkin Wireless G Plus MIMO Problem
connect a network cable to it. the open a web browser like internet explorer and type: http:\\192.168.1.1
A user interface should appear, the default password will be either 0000 or 1234.
Connect to your broadband provider (make sure you have a DSL lilght on solid, not flashing) and see can you browse the internet, you may need to put your username and password in the browser.
If you can browse you are now ready to setup your wirelees side of your network.
Disconnect the cable and activate your wireless on your pc/laptop. Search for your network name (this can be checked when connected to your router, usually under, wireless SSID name. Call it something you reconise)
Try connect to it now...
Hope this helps...
Feb 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to access program
Try pressing Ctrl+Shift+Esc to bring up task manager. Then on the top tabs, find the tab that says "Processes" and click it. Find the name of the program you are trying to delete under the Image Name. If you find it, click it and then click "End Process". Click Yes when the message comes up. If you don't find it, check the description (for Vista only).
The other way to do this is to log off and then log back on. If it still won't delete after that, try creating a new Limited User account, and then log onto the new account. Delete the file from that account. Log back on to your regular account and delete the Limited User account. Tada!
Feb 08, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
2wire 2700HG-B Router (2700HGB) Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
