Question about HTC Touch P3450 Smartphone
I have a touch by htc (sprint) can't get sound to come out when tv enabled
I have a touch by htc (sprint) I can't get the sound to come out when it is in the T. V. mode. Works with the music. Is there some setting that I am missing
  • Anonymous May 03, 2008
    have no sound coming out of my touch phone
  • Anonymous May 13, 2009
    I have HTC Touch and no sound of rear or back speaker.
  • 20 Answers
Download diamond tweak its a freeware , I believe it will help you to increase your volume a bit.
Write me for more details
MArshal
Dhaka, Bangladesh
Mobile Freak and Tester
Posted on May 24, 2010
I've had an issue with the sound not being as loud as it should be coming out of the rear speaker. The solution to this was to press the bottom navigation button (in this case, because Sprint TV requires you to view it in landscape mode, the nav button on the right near the bottom of the phone) to increase volume. I've found this helps. I don't know about NO sound coming out of the speaker but I'd check this option to see if it helps.
Posted on Jan 17, 2008
I need a phone manual for a HTC smartphone android
[PDF]User Manual - HTC.com dl3.htc.com/htc_na/user_guides/htc-touch-pro2-uscellular-ug.pdf HTC, the HTC logo, HTC Innovation, ExtUSB, HTC Sense, HTC Touch Pro, and HTC .... should be turned off and the user should obey all signs and instructions.
[PDF]Touch by HTC™ - Sprint Support
support.sprint.com/global/pdf/user_guides/htc/touch/htc_touch_ug.pdf HTC shall not be liable for technical or editorial errors or omissions contained herein, nor for .... 2.2 Using Touch Keypad or Touch Keyboard . ...... instructions.
Feb 01, 2016 | HTC Touch HD Smartphone
How can i unlock my htc pro 2
You can easily unlock HTC Touch Pro2. Just insert Invalid Sim card. it will ask you for unlock code. Enter unlock code. Your Locked Touch Pro will be Unlocked and able to accept any GSM Sim card.
You should buy an unlock code from a trusted HTC unlocking service.
Check the recommended link.
Feb 12, 2013 | HTC Touch Pro 2 / Tilt 2/ HTC XV6875/ S510...
How to reset my htc sprint unlock code , i forgot the code
As my knowledge, you can't reset HTC Touch P3450 unlock code if you forgot the code, but i have better solution to solve your problem. You just need to contact sprint provider and asking that HTC Unlock Code, and if you want an instant unlock code, you just need but that from online unlock code seller.
Aug 26, 2011 | HTC Touch P3450 Smartphone
Can Sprint HTC Touch Pro 2 unlocked? I just got one from Sprint (not activated yet) and are trying to unlock it - but do not know if it is possible.
it is possible with special equipment.
alternativley it may be able to be unlocked via code.
let me know what network it is locked to and which country. it is not free though as the code has to be purchased. iwill be able to give a price once i have the above info.
May 06, 2010 | HTC Touch Pro Smartphone
Htc touch diamond 2 screen is freezing cant call etc
1. Turn off HTC Home Sprint and Today Timeout. Settings -->Today --> Items --> Uncheck Today Timeout and HTC Home Sprint
2. Turn off Activesync. This can be done by closing activesync and going to Settings --> Phone --> Services --> Time synchronization and uncheck time sync. This will stop activesync from starting all the time
3. Turn Roaming to "SPRINT ONLY". Settings --> Phone --> Services --> Roaming --> SPRINT ONLY
Open the Task Manager (top right corner icon), clicked on the “tool” icon, then the “button” tab, and changed the “Enable the X button to end running programs,” selection form “End programs by tapping and holding X” to “End programs by tapping X.” Now, when you tap the “X” to close a program, it actually closes, and frees up more system memory. The same result can be achieved by tapping and holding the “X”, rather than changing the setting, if preferred. The objective is to CLOSE the programs and free up the memory.
Mar 23, 2010 | HTC Touch Diamond Smartphone
I have an htc touch 6900, by sprint and i downloaded
Edit the contact, where you could find an option to set Ringtone
Sep 14, 2009 | HTC Touch P3450 Smartphone
I have a htc touch MP6900SP. AND MY WINDOWS ARE LOCK
I just bought a sprint htc apply from the usa. Unfortunately I do not know how to use thephone. How do I use it?
Jun 02, 2009 | HTC Touch P3450 Smartphone
I Got Headphones By Motorolla Does It Work On Sprint Touch
i had an htc tilt and it was the same way the peoblem is that the audio connections are on the bottom of the connector and power is on the top i got an adapter from semsons.com that adapts a charger and regular headphones or go to htc or sprint for an adapter there supposed to come with the phone but some providers remove tem and sell them if you read the manual sometimes it will say use the (supplied) adapter but of course its missing hope this helps
Feb 11, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Using HTC Touch as modem via USB
Go here: http://www.isyougeekedup.com/how-to-enable-internet-connection-sharing-on-sprint-htc-touch-pro/ it worked for me. You need a registry editor to make changes to the Phone, try using this one instead: http://www.mydigitallife.info/2008/06/24/ceregeditor-free-desktop-based-registry-editor-for-windows-mobile-and-ce-pocket-pc-devices/, and as a personal note of precaution, make a full registry backup BEFORE you do any changes.
Jan 22, 2009 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
434 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
