Question about Mpio HD-400 MP3 Player
Hd400...solid? A year or longer ago I bought an mpio hd400 and, after 3 months it just died.. suddenly it got stucked on the loading screen and my pc couldnt recognize it. That was all...there was nothing I could do about it. ..I just thought I had been unlucky with that single one "solid"..BUT, two months ago a friend gave me as a birthday present the hd400 (he knew how much I liked and missed it), and it has happened exactly the same as with the first one! :( ..if anyone is wondering.. I treated them really well, never droped them or whatever. And I even didnt remove that protecting plastic (when i normally do remove it).. So.. I just have to say (it hurts because i loved this player) that the HD400 ISNT SOLID AT ALL... IT COULD BE CALLED A BEAUTIFUL SOLID SHIT maybe.. Sorry.
  • 3 Answers
Re: Hd400...solid? - Mpio HD-400 MP3 Player MP3 & Digital Media Players
Yeah I have the same problem with mine
Posted on May 14, 2008
0 characters
3 Points
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
Feb 29, 2008 | Mpio HD-300 MP3 Player
Hi, I can no longer browse through the files of my MPIO MG 100.
ok what charge setting is it on? if its on the MTP setting hold the "MENU" down until a message apears that says "reconnect the mg100 to change the mode" then it should work. if not then i guess i wasnt verry helpful and im sorry
Jun 05, 2009 | Mpio MP3 & Digital Media Players
No Light on My MPIO FL300
I have the same problem. I can store things in it but can't see the screen. the LED seems to have died first the light went out then it just died.. This is the 3rd Mpio FL300 that did that to me. I returned the 2 others before the warranty was out but this time it's to late. how do we fix this problem in other words how do I get the led to work????????
Jan 04, 2008 | Mpio FL300 MP3 Player
MPIO HD 300 Freezes/Computer won't recognize
1. there is a reset button if the player is stuck, there is a hole on the front panel use a paper clip.
2. Hard Drive probably got disconnected from the FPC cable, you might need to open the player to fix this issue
Dec 10, 2007 | Mpio HD-300 MP3 Player
Computer Won't Recognize Device
Try plugging your USB cable (attached to your player) into the computer before you turn the computer on and boot up . . . I had this same problem with a flash drive that the computer would not recognize if I plugged it into the computer while the computer was already on.
Aug 21, 2007 | Mpio FY500 MP3 Player
After knowledge more than help
Here is the link to the user manual for your player if you need it; The format of video that you play on the player will not be able to be shown on a tv without converting it using a different device - easiest and cheapest would be a pc, which basically makes it pointless using the player itself. it may be in the future that tvs will come on the market that accept a direct USB connection from devices like your player, but i havent found one yet available - keep checking. Sorry if not good news, hope it helps you out - please ask again if you want any more info :)
Apr 06, 2007 | Mpio HD-400 MP3 Player
Deep trouble with the memory..
ok you have to format by itself. reset the fl400 by the pinhole then when its off press play and menu at the same time for 10 seconds then press and hold the rec or rew button. after the format, run mpio utility press on setup & conf now you havet it like new
Jan 18, 2007 | Mpio FL400 MP3 Player
Frozen screen/ can't turn it off
Try the reset button which is pin-sized hole on bottom right when looking at the HD-400. You will need paper-clip to press it.
Jan 16, 2007 | Mpio HD-400 MP3 Player
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Nov 14, 2006 | Mpio HD-400 MP3 Player
Mpio HD-400 MP3 Player Logo
252 people viewed this question
Top Mpio MP3 & Digital Media Players Experts
 Mike M
Mike M
Are you a Mpio MP3 and Digital Media Player Expert? Answer questions, earn points and help others
